Configuration Overview
NAT table entries are used to filter out undesired IP addresses (deny list). After the packet from an endpoint is accepted through NAT filtering, policing is implemented in the Traffic Manager based on the sender’s IP address. NAT table entries are used to distinguish signaling packets coming in from different sources for policing purposes.
You can configure deny rules based on the following:
- ingress realm
- source IP address
- transport protocol (TCP/UDP)
- application protocol (SIP)
You can configure guaranteed minimum bandwidth for trusted and untrusted signaling paths.
You can configure signaling path policing parameters for individual source addresses. Policing parameters include:
- peak data rate in bits per second
- average data rate in bits per second
- maximum burst size
