Admission Control for Session Agents
This section explains how to configure session agents for admission control.
Session Agents Admission Control Configuration
To use admission control based on session rate, you need to configure session agent session rate constraints.
To configure session rates:
The following example shows session agent constraints that are enabled and the session capacity parameters have been configured. Other session agent parameters have been omitted for brevity.
session-agent constraints enabled max-sessions 355 max-inbound-sessions 355 max-outbound-sessions 355
The following example shows session agent constraints are enabled and the session rate parameters have been configured. Other session agent parameters have been omitted for brevity.
session-agent max-burst-rate 0 max-inbound-burst-rate 10 max-outbound-burst-rate 1 max-sustain-rate 3000 max-inbound-sustain-rate 0 max-outbound-sustain-rate 0 burst-rate-window 0 sustain-rate-window 0
Realm Bandwidth Configuration
To configure admission control based on bandwidth, you set the max and min bandwidth parameters in the realm configuration.
To configure realm bandwidth:
