Before You Configure
Before you configure your Oracle® Enterprise Session Border Controller to support this feature, note the following considerations:
- The ingress H.323 session agent cannot be configured with the NoPAssertedId option
- For use in Release 4.1.1 and higher, the global SIP configuration should be configured with the disable-ppi-to-pai option; the older disable-privacy option will also work
