IPv6 Link Local Addresses
The Oracle® Enterprise Session Border Controller supports IPv6 Link Local addresses configured for a network interface’s gateway.
An IPv6 link local address is signified by its first hextet set to FE80:. Even if a network interface’s first hextet is not FE80, but the gateway is, the Oracle® Enterprise Session Border Controller will still function as expected.
show neighbor-table
The show neighbor-table command displays the IPv6 neighbor table and validates that there is an entry for the link local address, and the gateway uses that MAC address.
System# show neighbor-table LINK LEVEL NEIGHBOR TABLE Neighbor Linklayer Address Netif Expire S Flags 300::100 0:8:25:a1:ab:43 sp0 permanent ? R 871962224 400::100 0:8:25:a1:ab:45 sp1 permanent ? R 871962516 fe80::bc02:a98f:f61e:20%sp0 be:2:ac:1e:0:20 sp0 4s ? R 871962808 fe80::bc01:a98f:f61e:20%sp1 be:1:ac:1e:0:20 sp1 4s ? R 871963100 ------------------------------------------------------------------------------ ICMPv6 Neighbor Table: ------------------------------------------------------------------------------------------ entry: slot port vlan IP type flag pendBlk Hit MAC ------------------------------------------------------------------------------------------ 5 : 1 0 0 fe80::bc01:a98f:f61e:20/64 08-DYNAMIC 1 0 1 be:01:ac:1e:00:20 4 : 1 0 0 0.0.0.0/64 01-GATEWAY 0 0 1 be:01:ac:1e:00:20 3 : 1 0 0 400::/64 02-NETWORK 0 0 1 00:00:00:00:00:00 2 : 0 0 0 fe80::bc02:a98f:f61e:20/64 08-DYNAMIC 1 0 1 be:02:ac:1e:00:20 1 : 0 0 0 0.0.0.0/64 01-GATEWAY 0 0 1 be:02:ac:1e:00:20 0 : 0 0 0 300::/64 02-NETWORK 0 0 1 00:00:00:00:00:00 ------------------------------------------------------------------------------------------
