Setting Up System Basics
Before configuring and deploying the Oracle® Enterprise Session Border Controller, you might want to establish some basic attributes such as a system prompt, new User and Superuser passwords, and NTP synchronization.
New System Prompt
The ACLI system prompt is set in the boot parameters. To change it, access the boot parameters and change the target name value to make it meaningful within your network. The target name may be up to 38 characters. A value that identifies the system in some way is often helpful.
Set Initial Passwords for Admin and User
The Oracle® Enterprise Session Border Controller (E-SBC) requires you to set passwords for the Admin and User accounts the first time you power up a new or factory reset system by way of local access. You cannot access the Admin and User accounts until you set the corresponding passwords. Use either an SSH or console connection when setting passwords. The following procedure is for local access. If you use remote access, for example, RADIUS or TACACS, use your passwords for those services.
- 8-64 characters
- Include three of the
following:
- Lower case letters
- Uppercase letters
- Numerals
- Punctuation
