Management Commands for the Web Server
The following commands allow you to display information for managing the Web server used for accessing the GUI.
| Command | Description |
| show ip connections | Displays information about the server connections. |
| show users | Displays information about users logged into a session on the server. |
| kill <index> | Terminates a session on the server. |
Show ip connections Command
The show ip connections command allows you to display information about active server Transport Control Protocol (TCP) and/or User Datagram Protocol (UDP) connections. For example, this command can show the sockets tied to an HTTPS connection. The following is an example of the show ip connections command output.
ACMEPACKET# show ip connections Active Internet connections (including servers) PCB Proto Recv-Q Send-Q Local Address Foreign Address (state) -------- ----- ------ ------ --------------------- --------------------- ------- 75059a0 TCP 0 0 172.30.80.231.1538 172.30.0.39.58497 TIME_WAIT 7506420 TCP 0 0 172.30.80.231.443 10.1.20.14.51006 TIME_WAIT 75044a0 TCP 0 0 172.30.80.231.443 10.1.20.14.51000 TIME_WAIT 7504f20 TCP 0 0 172.30.80.231.443 10.1.20.14.50997 TIME_WAIT 7503f60 TCP 0 0 127.0.0.1.3000 127.0.0.1.1064 ESTABLISHED 7503a20 TCP 0 0 127.0.0.1.3000 127.0.0.1.1063 ESTABLISHED 75034e0 TCP 0 0 127.0.0.1.3000 127.0.0.1.1062 ESTABLISHED 7502fa0 TCP 0 0 127.0.0.1.3000 127.0.0.1.1061 ESTABLISHED 7502a60 TCP 0 0 127.0.0.1.3000 127.0.0.1.1060 ESTABLISHED 7502520 TCP 0 0 127.0.0.1.1063 127.0.0.1.3000 ESTABLISHED 7501fe0 TCP 0 0 127.0.0.1.1062 127.0.0.1.3000 ESTABLISHED 7501aa0 TCP 0 0 127.0.0.1.1061 127.0.0.1.3000 ESTABLISHED
The following table describes each column in the above output.
| Column Heading | Description |
| PCB | Printed circuit board in the server that is active on the connection. |
| Proto | Protocol used on this connection. Valid values
are:
TCP - Transport Control Protocol UDP - User Datagram Protocol |
| Recv-Q | Receiving queue - pertains to the queue on the server that receives packets from the Internet. This column should always display a zero (0). Packets should not be piling up in this queue. |
| Send-Q | Sending queue - pertains to the queue on the server that sends out packets to the Internet. This column should always display a zero (0). Packets should not be piling up in this queue. |
| Local Address | Local server’s IP address and port number, or IP address and the name of a service. |
| Foreign Address | Hostname and service, or IP address and port number to which you are connected. The asterisk is a placeholder for IP addresses, which of course cannot be known until a remote host connects. |
| (state) | Current state of the TCP or UDP connection. TCP
states can be:
LISTEN waiting to receive a connection ESTABLISHED a connection is active TIME_WAIT a recently terminated connection; this should last only a minute or two, then change back to LISTEN. The socket pair cannot be re-used as long the TIME_WAIT state persists. UDP is stateless, so the "State" column is always blank. |
Show users Command
The show users command displays information about users currently logged into a session on the server. Each user is indicated by an index number. The following is an example of the show users command output.
The index number for Web sessions always begins at 31.ACMEPACKET# show users
Index task-id remote-address IdNum duration type state User
0 0x33a4c394 0 00:01:20 console user * console
31 NA 10.1.20.14:51218 31 00:00:55 http user user
32 NA 10.1.20.14:443 32 00:00:29 https user user
| Index | Number that the server assigns to the user as
an identification of that user.
Note: The index for Web sessions always begins at index 31. |
| Task-id | Alpha-numeric number that the server assigns to the task currently being performed. This is the session ID assigned to the task at log-in time. This field is not applicable to the Web server. |
| Remote-address | IP address and port number for which the server is connected. |
| IdNum | Identification number of the user currently logged into the server. This number is the same as the Index number. |
| Duration | Amount of time, in hours, minutes, and seconds, that the user has currently been logged into a session on the server. Format is HH:MM:SS. |
| Type | Type of service that the user is currently
using for connection to the server. Valid values can be:
Console User is connected to the server via a local console. HTTP User is connected to the server using a Web HTTP service. HTTPS User is connected to the server using a secure Web HTTPS service. |
| State | Current state of the connection on the server.
Valid values are:
admin user Note: An “*’ indicates a current connection. |
| User | Current user type logged into the server. Valid
values are:
console user admin |
Kill <index> Command
The kill <index> command terminates a session on the server. The following example uses the “show users” command to display the index number to use with the kill <index> command.
ACMEPACKET# kill 31
The kill 31 command terminates the Web server session number 31.
After setting the Web server configuration, you can view the stored monitored data from the Oracle® Enterprise Session Border Controller (E-SBC) using the GUI through an Internet browser. For more information about the GUI, see Configuring TLS on the Web Server.
