Set Up High Availability Mode
Use the following procedure to configure High Availability (HA) on a primary and secondary Oracle® Enterprise Session Border Controller (E-SBC).
Confirm that you own an HA license.
In the following procedure, enter y to discard any changes and quit the installation wizard. The root prompt displays.
A “Warning” displays stating that using the wizard can overwrite (erase) the existing running configuration. If you want to back out of the setup process and not overwrite the current running configuration, you can enter q or enter No at the Erase config and proceed prompt. The root prompt displays.
For HA environments, running setup on the secondary system is also required to set the wancom0 address and secondary targetname. The targetname must match the same secondary targetname specified on the primary system.To configure the primary High Availability (HA):
In Superuser mode, type
run setup
, and press Enter.
ORACLE# run setup
- Type yes to continue the setup process, and press Enter.
Type either
yes or
no to enable or disable the Web GUI, and press Enter.
Enable Web GUI (yes/no) [yes] :yes
The system displays the following:
========================================================= WEB GUI MODE Choose which mode to enable for the web GUI Web GUI Mode 1 - basic 2 - expert Enter choice [1 - basic] : =========================================================
Type
1
to enable Basic Mode and Expert Mode, or type
2
to enable Expert Mode, only. Press Enter.
If you enable both Basic and Expert Modes (selection 1), after logging into the Web GUI, the Basic Mode screen displays by default. You can switch to Expert Mode if you do not make any changes in Basic Mode, using the Switch to Expert button. If you enable Expert Mode only (selection 2), no button displays to switch to Basic Mode.
========================================================= HIGH AVAILABILITY This SBC may be a standalone or part of a highly available redundant pair. SBC mode 1 - standalone 2 - high availability Enter choice [1 - standalone] : =========================================================
Type
2 to configure an HA device, and press Enter.
Enter choice [1 - standalone] :2
========================================================= If this SBC is the primary, enter the configuration. If it is the secondary, you can import settings from the primary. SBC role 1. primary 2. secondary Enter choice [1-primary] : =========================================================
Enter
2, and press Enter.
Enter choice [1-primary] :2
========================================================= SBC SETTINGS Unique target name of this SBC [<NN-ESD name>] : =========================================================
Type
a unique target name for the NN-ESD (or keep the default in [ ]),
, and press Enter.
Unique target name of this SBC [NNESD1] :NNESD2
========================================================= SBC SETTINGS IP address on management interface [<SBC IP address>] : =========================================================
The Installation Wizard provides default IP addresses for the HA primary and secondary peers (Redundancy interface address and Peer IP address ). These default addresses are link-local addresses as specified in RFC 3927, Dynamic Configuration of IPv4 Link-local addresses. -
Type
the IP address on the management interface of the secondary Web Server (or keep the default in [ ]),
, and press Enter.
IP address on management interface [<SBC IP address>] : 164.30.85.52
Subnet mask [255.255.0.0] : =========================================================
Type
the subnet mask of the secondary Web Server (or keep the default in [ ]),
, and press Enter.
Subnet mask [255.255.0.0] : 255.255.0.0
========================================================= Gateway IP address [164.30.0.1] : =========================================================
Type the gateway IP address of the secondary Web Server (or keep the default in [ ]), and press Enter.
Gateway IP address [<SBC gateay address>] : 164.30.0.1
========================================================= AUTOMATIC CONFIGURATION Acquire config from the Primary (yes/no) [yes] : =========================================================
Type
y for the secondary Web Server to acquire the configuration from the primary Web Server during switchover, and press Enter.
Acquire config from the Primary (yes/no) [yes] y
========================================================= -- Summary view ------------------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : high availability 4 : SBC role : secondary SBC SETTINGS 7 : Unique target name of this SBC : NNESD2 8 : IP address on management interface : 164.30.85.52 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : yes PEER CONFIGURATION 13: Peer target name : N/A Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s]: =========================================================
Types to save the configuration, and press Enter. Or, Select an item number from the summary view to modify the value for that item. Or, type
q to exit the installation wizard.
Enter 1 - 16 to modify, 'd' to display summary, 's' to save, 'q' to exit. [s] :s
========================================================= Saving changes and quitting wizard. Are you sure? [y/n]? : =========================================================
Type y to verify you want to save the configuration, and press Enter.
========================================================= Running configuration is backed up as 'bkup_setup_wizard_Mar__7_13_58_26_545.gz' ****************************************************** Deleting configuration Erase-Cache received, processing. waiting 1200 for request to finish Request to 'ERASE-CACHE' has Finished, Erase-Cache: Completed Request to 'RESTORE-CONFIG' has Finished, Restore Backup Completed Successfully checking configuration Save-Config received, processing. waiting for request to finish Request to 'SAVE-CONFIG' has Finished, Save complete Currently active and saved configurations do not match! To sync & activate, run 'activate-config' or 'reboot activate'. --------------------------------------------------------------------- Verification successful! No errors nor warnings in the configuration Activate-Config received, processing. waiting for request to finish Request to 'ACTIVATE-CONFIG' has Finished, Activate Complete -- Saved configuration. ---------------------------- GUI ACCESS 1: Enable Web GUI (yes/no) : yes WEB GUI MODE 2 : Web GUI Mode : basic HIGH AVAILABILITY 3 : SBC mode : high availability 4 : SBC role : secondary SBC SETTINGS 7 : Unique target name of this SBC : NNESD2 8 : IP address on management interface : 164.30.85.52 9 : Subnet mask : 255.255.0.0 10: Gateway IP address : 164.30.0.1 AUTOMATIC CONFIGURATION 11: Acquire config from the Primary (yes/no) : yes PEER CONFIGURATION 13: Peer target name : N/A You may access the GUI via http://164.30.85.52:80/ after reboot. =========================================================
You have completed the Installation Wizard.
Run the Installation Wizard on the secondary peer of the HA pair.
