Call Duration Counters
The Oracle® Enterprise Session Border Controller maintains aggregate call duration in seconds for the current period, lifetime total and the lifetime-period-maximum. These counters are maintained for each session agent, realm, SIP Interface, and globally across the system. The call duration counter can count up to a 32 bit value, after which time it rolls over.
- show sipd agents
- show sipd realms
- show sipd interface
- show sipd status
Call Duration Calculation
Call duration is calculated as the time between (t1) when the E-SBC receives the 200OK for the INVITE from terminating endpoint, and (t2) the time when E-SBC receives the final 200OK for the BYE message from terminating endpoint, regardless of whether media is released. If the set-disconnect-time-on-bye parameter is enabled in the sip-config, then the call termination time (t2') is when the E-SBC receives the BYE message originally from the endpoint ending the call.
Figure 4-1 Call Duration Calculation Example - Ladder Diagram
Table 4-1 Call Duration Calculation Example - Results
| Element | Inbound Duration (sec) | Outbound Duration (sec) |
| Session Agent: SA-1 | t2 - t1 | 0 |
| Session Agent: SA-2 | 0 | t2 - t1 |
| Realm: InRealm | t2 - t1 | 0 |
| Ream: OutRealm | 0 | t2 - t1 |
| Interface: 1.1.1.1 | t2 - t1 | 0 |
| Interface: 2.2.2.2 | 0 | t2 - t1 |
The global system call duration for the previous example is t2' - t1 seconds if the set-disconnect-time-on-bye parameter is enabled.
