Configuring General System Information
This section explains how to configure the general system parameters, timeouts, and the default gateway necessary to configure your Oracle® Enterprise Session Border Controller.
To configure general system information:
System Identification
You must specify identification parameters for this Oracle® Enterprise Session Border Controller.
Set the following parameters to configure the system identification:
- hostname—Set the primary hostname used to identify the system. This parameter is used by the software for informational purposes.
- description—Enter a textual description of thesystem. This parameter is used for informational purposes.
- location—Set a location description field for your system. This parameter is used for informational purposes. For example, you could include the site name and address of the location where the Oracle® Enterprise Session Border Controller system chassis is located.
- default-gateway—Set the default gateway for this Oracle® Enterprise Session Border Controller. This is the egress gateway for traffic without an explicit destination. The application of your Oracle® Enterprise Session Border Controller determines the configuration of this parameter.
