HA Configuration Checkpointing
You need to first set applicable network interface configuration parameters, and then establish applicable parameters in the Oracle® Enterprise Session Border Controller HA node (redundancy) configuration.
We recommend that you do not change the configuration checkpointing parameters in the redundancy configuration. Using the defaults, this feature will function as designed.
Remember to set the appropriate type parameter in the HA node redundancy peers configuration.For the network interface, these parameters appear as they do in the following example when you use the ACLI. This example has been shortened for the sake of brevity.
pri-utility-addr 169.254.1.1 sec-utility-addr 169.254.1.2
For the Oracle® Enterprise Session Border Controller HA node (redundancy) configuration, these parameters appear as they do in the following example when you use the ACLI. This example has been shortened for the sake of brevity. You should not change these values without consultation from Oracle Technical Support or your Oracle Systems Engineer.
cfg-port 1987 cfg-max-trans 10000 cfg-sync-start-time 5000 cfg-sync-comp-time 1000
To configure HA configuration checkpointing in the ACLI:
