Examples
Ex Messages on Originating Call Leg Ingress SIP Interface Config Ingress SIP Interface Config Messages on Terminating Call Leg
1 INVITE →
  • Supported: timer
    SE: 200
  • ← 200 OK
    Require: timer
    SE: 200; refresher=uas
  • INVITE →
    Supported: timer
    SE: 1200; refresher=uas
← 200 OK
Require: timer
SE: 500; refresher=uas
session-expires: 500
min-se: 200
request-refresher: none
response-refresher: uas
this element becomes refresher
min-se: 400
  • INVITE→
    Supported: timer
    SE: 500
    Min-se: 400
  • ← 200 OK
    Require: timer
    SE: 400; refresher=uas
2 session-expires: 500
min-se: 200
response-refresher: uac
min-se: 400
request-refresher: uas
INVITE →
Supported: timer
Min-se: 400
← 200 OK
3 INVITE →
Supported: timer
SE: 1200; refresher=uac
Min-se: 800
← 200 OK
Require: timer
SE: 800; refresher=uac
min-se: 200
No session timer configuration
INVITE →
Supported: timer
← 200 OK
Require: timer
SE: 400; refresher=uac
4 INVITE →
Supported: timer
SE: 200; refresher=uac
← 200 OK
Require: timer
min-se: 200
No session timer configuration INVITE →
Supported: timer
← 200 OK
5 INVITE →
Supported: timer
SE: 200
← 200 OK
No session timer configuration session-expires: 500
min-se: 400
INVITE →
Supported: timer
Min-se: 400
← 200 OK
6 INVITE →
Supported: timer
SE: 200
← 200 OK
Require: timer
SBC behavior stays same as current behavior
Supported: timer
SE: 200
← 200 OK
Require: timer
7 INVITE →
Require: timer
SE: 200
← 420
Unsupported: timer
No SIP feature for timer
SD behavior stays same as current behavior
8 INVITE →
Require: timer
SE: 200
← 420
Unsupported: timer
SIP feature configured for timer
Required: timer
SE: 200
← 420
Unsupported: timer
9 INVITE →
Require: timer
SE: 200
← 200 OK
min-se: 400
INVITE →
Supported: timer
SE: 500
Min-se: 400
← 200 OK
Require: timer
SE: 500; refresher=uac
10 INVITE →
Require: timer
SE: 200
← 200 OK
Require: timer
min-se: 200
min-se: 400
INVITE →
Supported: timer
Min-se: 400
← 200 OK
Require: timer
11 INVITE →
Require: timer
SE: 200
← 420
Unsupported: timer
min-se: 400
12 INVITE →
SE: 200
← 200 OK
min-se: 500
← 200 OK
13 INVITE →
← 200 OK
min-se: 400
INVITE →
Supported: timer
SE: 500
Min-se: 400
← 200 OK
Require: timer
14 INVITE →
← 421
Require: timer
15 INVITE →
Supported: timer
SE: 200
← 422
Min-se: 400
min-se: 400
16 INVITE →
Supported: timer
SE: 200
← 200 OK
Require: timer
session-expires: 800
min-se: 90
min-se: 90
INVITE →
Supported: timer
SE: 800
Min-se: 90
← 422
Min-se: 900
INVITE →
Supported: timer
SE: 900
Min-se: 900
← 200 OK
Require: timer
SE: 900; refresher=uas
