PreviousNextJavaScript must be enabled to correctly display this content
Configuring Graceful Call Control
You can enable the
Oracle® Enterprise Session Border Controller to stop receiving session-initiating traffic on a media interface when the traffic for the interface exceeds the critical threshold you define for it.
To enable graceful call control:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminalORACLE(configure)#
Type
system and press Enter.
ORACLE(configure)# systemORACLE(system)#
Type
phy-interface
and press Enter.
If you are adding this feature to an existing configuration, then remember you must select the configuration you want to edit.
overload-protection—Change this parameter’s value to enabled if you want to turn graceful call control on. Leave it set to disabled (default) if you do not want to use this feature.
