Configure IWF
To enable the Inter-working Function (IWF) on your Oracle® Enterprise Session Border Controller :
Access the
iwf-config configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# iwf-config ORACLE(iwf-config)#
state—Enable this parameter if you want to translate SIP and H.323 sessions on your
Oracle® Enterprise Session Border Controller . The default value is
disabled. Valid values are:
enabled | disabled
media-profiles—Enter the name of the media profiles you want to use for IWF translations. This name is either the name of an SDP codec (such as PCMU), or it can be telephone-event if you are configuring your system for DTMF support.
If you want to use more than one media profile for SIP/H.323 translations, enter the names in quotation marks with a space between each one.
ORACLE(iwf-config)# media-profiles "PCMU telephone-event"
logging—Enable this parameter if you want the
Oracle® Enterprise Session Border Controller to log SIP messages that are related to the IWF. The default value is
enabled | disabled
forward source call—Type
enable if you want to the
Oracle® Enterprise Session Border Controller to add the
h225SourceCallSignalAddressheader to the egress SIP INVITE. - Type done to save your configuration.
