VLANs
One parameter is required to configure VLANs on a Oracle® Enterprise Session Border Controller. The sub-port-id parameter located in the network-interfaces element adds and masks for a specific VLAN tag.
sub-port-id—Enter the identification of a specific virtual interface in a
phy-interface (e.g., a VLAN tab). If this network interface is not channelized, leave this field blank, and the value will correctly default to
0. The
sub-port-id is only required if the operation type is Media. The valid range is:
Minimum—0
Maximum—4095.
