Configuring DoS Security
This section explains how to configure the Oracle® Enterprise Session Border Controller for DoS protection.
Configuration Overview
Configuring Oracle® Enterprise Session Border Controller DoS protection includes masking source IP and port parameters to include more than one match and configuring guaranteed minimum bandwidth for trusted and untrusted signaling path. You can also configure signaling path policing parameters for individual source addresses. Policing parameters are defined as peak data rate (in bytes/sec), average data rate (in bytes/sec), and maximum burst size.
You can configure deny list rules based on the following:
- ingress realm
- source IP address
- source port
- transport protocol (TCP/UDP)
- application protocol (SIP or H.323)
Changing the Default Oracle® Enterprise Session Border Controller Behavior
The Oracle® Enterprise Session Border Controller automatically creates permit untrusted ACLs that let all sources (address prefix of 0.0.0.0/0) reach each configured realm’s signaling interfaces, regardless of the realm’s address prefix. To deny sources or classify them as trusted, you create static or dynamic ACLs, and the global permit untrusted ACL to specifically deny sources or classify them as trusted. Doing this creates a default permit-all policy with specific deny and permit ACLs based on the realm address prefix.
You can change that behavior by configuring static ACLs for realms with the same source prefix as the realm’s address prefix; and with the trust level set to the same value as the realm. Doing this prevents the permit untrusted ACLs from being installed. You then have a default deny all ACL policy with specific static permit ACLs to allow packets into the system.
Example 1 Limiting Access to a Specific Address Prefix Range
The following example shows how to install a permit untrusted ACL of source 12.34.0.0/16 for each signalling interface/port of a realm called access. Only packets from within the source address prefix range 12.34.0.0/16, destined for the signaling interfaces/port of the realm named access, are allowed. The packets go into untrusted queues until they are dynamically demoted or promoted based on their behavior. All other packets are denied/dropped.
- Configure a realm called access and set the trust level to low and the address prefix to 12.34.0.0/16.
- Configure a static ACL with a source prefix of 12.34.0.0/16 with the trust level set to low for the realm named access.
Example 2 Classifying the Packets as Trusted
Building on Example 1, this example shows how to classify all packets from 12.34.0.0/16 to the realm signaling interfaces as trusted and place them in a trusted queue. All other packets from outside the prefix range destined to the realm’s signaling interfaces are allowed and classified as untrusted; then promoted or demoted based on behavior.
You do this by adding a global permit untrusted ACL (source 0.0.0.0) for each signaling interface/port of the access realm. You configure a static ACL with a source prefix 12.34.0.0/16 and set the trust level to high.
Adding this ACL causes the Oracle® Enterprise Session Border Controller to also add a permit trusted ACL with a source prefix of 12.34.0.0/16 for each signaling interface/port of the access realm. This ACL is added because the trust level of the ACL you just added is high and the realm’s trust level is set to low. The trust levels must match to remove the global permit trusted ACL.
Example 3 Installing Only Static ACLs
This example shows you how to prevent the Oracle® Enterprise Session Border Controller from installing the global permit (0.0.0.0) untrusted ACL.
- Configure a realm with a trust level of none.
- Configure static ACLs for that realm with the same source address prefix as the realm’s address prefix, and set the trust level to any value.
The system installs only the static ACLs you configure.
Host Access Policing
You can configure the Oracle® Enterprise Session Border Controller to police the overall bandwidth of the host path.
To configure host access policing:
Configuring ARP Flood Protection
You do not need to configure the Oracle® Enterprise Session Border Controller to enable the use of two separate ARP queues; that feature is enabled automatically.
If you want to configure the ARP queue policing rate, you can do so in the media manager configuration.
this feature is not RTC-supported, and you must reboot your Oracle® Enterprise Session Border Controller in order for your configuration changes to take effect.To set the ARP queue policing rate:
Access Control for a Realm
Each host within a realm can be policed based on average rate, peak rate, and maximum burst size of signaling messages. These parameters take effect only when the host is trusted. You can also set the trust level for the host within the realm. All untrusted hosts share the bandwidth defined for the media manager: maximum untrusted bandwidth and minimum untrusted bandwidth.
To configure access control for a realm:
Configuring Overload Protection for Session Agents
The Oracle® Enterprise Session Border Controller offers two methods to control SIP registrations to smooth the registration flow.
You can limit the:
- number of new register requests sent to a session agent (using the max-register-sustain-rate parameter)
- burstiness which can be associated with SIP registrations
The first method guards against the Oracle® Enterprise Session Border Controller’s becoming overwhelmed with register requests, while the second method guards against a transient registration that can require more than available registration resources.
SIP registration burst rate control allows you to configure two new parameters per SIP session agent—one that controls the registration burst rate to limit the number of new registration requests, and a second to set the time window for that burst rate. When the registration rate exceeds the burst rate you set, the Oracle® Enterprise Session Border Controller responds to new registration requests with 503 Service Unavailable messages.
Note that this constraint is not applied to re-registers resulting from a 401 Unauthorized challenge request.
To configure overload protection for session agents:
