Media Inactivity Timer Configuration
To disable the media inactivity timer for calls placed on hold:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager-config
and press Enter.
ORACLE(media-manager)# media-manager-config ORACLE(media-manager-config)#
options—Set the options parameter by typing
options, a Space, the option-name
disable-guard-timer-sendonly with a plus sign in front of it, and then press Enter.
ORACLE(media-manager-config)# options +disable-guard-timer-sendonly
If you type the option without the plus sign, you will overwrite any previously configured options. In order to append the new options to the SIP interface configuration’s options list, you must prepend the new option with a plus sign as shown in the previous example.
- Save and activate your configuration.
