REFER Source Routing Configuration
To enable realm-based REFER method call transfer:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
media-manager
and press Enter.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config and press Enter.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
- refer-call-transfer — Retain the default (disabled) to proxy all REFERs to the next hop. Use enabled to terminate all REFERs and issue a new INVITE. Use dynamic to specify REFER handling on a call-by-call basis, as determined by the value of the dyn-refer-term parameter.
- dyn-refer-term (meaningful only when refer-call-transfer is set to dynamic) — Retain the default (disabled) to terminate the REFER and issue a new INVITE. Use enabled to proxy the REFER to the next hop.
Save and activate your configuration.
To enable session-agent-based REFER method call transfer:
Type
session-router
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent and press Enter.
ORACLE(media-manager)# session-agent ORACLE(session-agent)#
To specify policy lookup for a newly generated INVITE:
Type
session-router
and press Enter.
Type
sip-config
and press Enter.
ORACLE(configure)# sip-config ORACLE(sip-config)#
- refer-src-routing — Retain the default (disabled) to perform a policy lookup based upon the source realm of the calling party (the issuer of the original INVITE). Use enabled to perform a policy lookup based upon the source realm of the referring party (the issuer of the REFER).
- Save and activate your configuration.
