ACLI Signaling Mode Configuration Examples
The following ACLI displays provide examples of the Signaling Modes of Operation described earlier in this chapter.
Configuration Fields and Values for B2BGW Signaling
This example provides is a sample for the Back-to-Back Gateway Signaling mode of operation.
h323-config
state enabled
log-level INFO
response-tmo 4
connect-tmo 32
h323-stack
name zone1
state enabled
isgateway enabled
realm-id zone1realm
assoc-stack zone2
local-ip x.x.x.x (IP address of VGW-A)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
auto-gk-discovery enabled
multicast 224.0.1.41:1718
gatekeeper x.x.x.x (IP address of GkZone1)
gk-identifier gk-zone1.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
h245-tunneling enabled
fs-in-first-msg disabled
call-start-fast disabled
call-start-slow disabled
media-profiles
process-registration disabled
anonymous-connection disabled
proxy-mode
filename
h323-stack
name zone2
state enabled
isgateway enabled
realm-id DomainCrealm
assoc-stack zone1
local-ip x.x.x.x(IP address of VGW-C)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=acme01
ras-port 1719
gatekeeper x.x.x.x(IP address of GkZONE2)
gk-identifier gk-zone2.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone3
state enabled
isgateway enabled
realm-id zone3realm
assoc-stack zone4
local-ip x.x.x.x(IP address of VGW-B)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
gatekeeper x.x.x.x(IP address of GkZone3)
gk-identifier gk-zone3.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone4
state enabled
isgateway enabled
assoc-stack zone3
local-ip x.x.x.x(IP address of VGW-D)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
gatekeeper x.x.x.x(IP address of GkZone4)
gk-identifier gk-zone4.acme.com
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
Back-to-Back Gatekeeper Proxy and Gateway
This example provides is a sample for the Back-to-Back Gateway Proxy and Gateway mode of operation.
h323-config
state enabled
log-level INFO
response-tmo 4
connect-tmo 32
h323-stack
name zone1
state enabled
isgateway disabled
realm-id zone1realm
assoc-stack zone2
local-ip x.x.x.x(IP address of VGW-A/GK-A)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
auto-gk-discovery disabled
multicast 0.0.0.0:0
gatekeeper x.x.x.x(IP address of GkZone1)
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone2
state enabled
isgateway disabled
assoc-stack zone1
local-ip x.x.x.x(IP address of VGW-C/GK-C)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=acme01
ras-port 1719
multicast 0.0.0.0:0
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone3
state enabled
isgateway disabled
realm-id zone3realm
assoc-stack zone4
local-ip x.x.x.x(IP address of VGW-B/GK-B)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone4
state enabled
isgateway disabled
assoc-stack zone3
local-ip x.x.x.x(IP address of VGW-D/GK-D)
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
alternate-transport
q931-port 1720
q931-max-calls 200
media-profiles
proxy-mode
filename
Interworking Gatekeeper-Gateway
This example provides is a sample for the Interworking Gatekeeper-Gateway mode of operation.
h323-config
state enabled
log-level INFO
response-tmo 4
connect-tmo 32
h323-stack
name zone1
state enabled
isgateway disabled
realm-id zone1realm
assoc-stack zone2
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone2
state enabled
isgateway enabled
assoc-stack zone1
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=acme01
ras-port 1719
multicast 0.0.0.0:0
gatekeeper 0.0.0.0:0
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone3
state enabled
isgateway disabled
realm-id zone3realm
assoc-stack zone4
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
q931-port 1720
alternate-transport
q931-max-calls 200
media-profiles
proxy-mode
filename
h323-stack
name zone4
state enabled
isgateway enabled
assoc-stack zone3
max-calls 200
max-channels 10
registration-ttl 0
terminal-alias
h323-ID=private
ras-port 1719
multicast 0.0.0.0:0
