Configuring SIP Privacy Extensions
Prior to this release the session agent’s trust mode provided this functionality. Now you configure SIP interface’s trust-mode as none, which means nothing is trusted for this SIP interface.
You also configure the disable-ppi-to-pai parameter disable the changing of the P-Preferred header to the P-Asserted-Identity header, if the outgoing side is trusted.
