LRT String Lookup
The Oracle® Enterprise Session Border Controller can search an LRT for either E.164 or string table keys. This selection is on a global basis. When the string-lookup parameter is disabled (default) in the local routing configuration, all lookups with be E.164 type, except when:
  • If eloc-str-lkup is enabled in a matching local policy’s policy-attribute, E-CSCF procedures are applied and the resulting lookup type is 'string'.
  • The Oracle® Enterprise Session Border Controller also performs string lookups exclusively when a compound lookup key is specified.
When the lookup type is 'E.164', the lookup is skipped if the lookup key is not a valid telephone number (i.e. it must contain only digits).
LRT String Lookup Configuration
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
  2. Type session-router and press Enter.
    ORACLE(configure)# session-router
  3. Type local-routing-config and press Enter.
    ORACLE(session-router)# local-routing-config
    ORACLE(local-routing-config)#
  4. string-lookup—Set this parameter to enabled for the Oracle® Enterprise Session Border Controller to perform LRT lookups on table keys of a string data type. Leave this parameter to its default as disabled to continue using E.164 type lookups.
  5. Save your work using the done command.
