RADIUS Support for IPv6
The Oracle® Enterprise Session Border Controller’s RADIUS support includes:
- RADIUS CDR generation for SIPv6-SIPv6 and SIPv6-SIPv4 calls
- IPv6-based addresses in RADIUS CDR attributes
The sixteen-byte requirement for IPv6 addresses is supported, and there is a set of attributes with the type ipv6addr. Attributes 155-170 are reserved for the IPv6 addresses.
NAS addresses use the number 95 to specify the NAS-IPV6-Address attribute. And local CDRs now contain IPv6 addresses.
Supporting RADIUS VSAs
The following VSAs have been added to the Oracle RADIUS dictionary to support IPv6.
Acme-Flow-In-Src-IPv6_Addr_FS1_F 155 ipv6addr Acme Acme-Flow-In-Dst-IPv6_Addr_FS1_F 156 ipv6addr Acme Acme-Flow-Out-Src-IPv6_Addr_FS1_F 157 ipv6addr Acme Acme-Flow-Out-Dst-IPv6_Addr_FS1_F 158 ipv6addr Acme Acme-Flow-In-Src-IPv6_Addr_FS1_R 159 ipv6addr Acme Acme-Flow-In-Dst-IPv6_Addr_FS1_R 160 ipv6addr Acme Acme-Flow-Out-Src-IPv6_Addr_FS1_R 161 ipv6addr Acme Acme-Flow-Out-Dst-IPv6_Addr_FS1_R 162 ipv6addr Acme Acme-Flow-In-Src-IPv6_Addr_FS2_F 163 ipv6addr Acme Acme-Flow-In-Dst-IPv6_Addr_FS2_F 164 ipv6addr Acme Acme-Flow-Out-Src-IPv6_Addr_FS2_F 165 ipv6addr Acme Acme-Flow-Out-Dst-IPv6_Addr_FS2_F 166 ipv6addr Acme Acme-Flow-In-Src-IPv6_Addr_FS2_R 167 ipv6addr Acme Acme-Flow-In-Dst-IPv6_Addr_FS2_R 168 ipv6addr Acme Acme-Flow-Out-Src-IPv6_Addr_FS2_R 169 ipv6addr Acme Acme-Flow-Out-Dst-IPv6_Addr_FS2_R 170 ipv6addr Acme
