View Statistics
To view statistics for NTP servers:
- At the command line, type show ntp server and press Enter.
ORACLE# show ntp server NTP Status FRI APR 11:09:50 UTC 2007 server st poll reach delay offset disp ----------------------- -- ---- ------ ------- -------- --------- *64.46.24.66 3 64 377 0.00018 0.000329 0.00255 =61.26.45.88 3 64 377 0.00017 0.002122 0.00342
You can the see the status of NTP on your system by using the show ntp status command. Depending on the status of NTP on your system, one of the following messages will appear:
- NTP not configured
- NTP Daemon synchronized to server at [the IP address of the specific server]
- NTP synchronization in process
- NTP down, all configured servers are unreachable
