PreviousNextJavaScript must be enabled to correctly display this content
Configuring Connection and Debug Logging Timeouts
Configure the timeouts for terminal sessions on this Oracle® Enterprise Session Border Controller. These parameters are optional.
Set the following parameters to configure the connection timeouts:
telnet-timeout—Set the Telnet timeout to the number of seconds you want the Oracle® Enterprise Session Border Controller to wait before it disconnects a Telnet session or an SSH session. The default value is 0. The valid range is:
Minimum—0
Maximum—65535
console-timeout—Set the console timeout to the number of seconds you want the Oracle® Enterprise Session Border Controller to wait before it ends the console session. The default value is 0. The valid range is:
Minimum—0
Maximum—65535
debug-timeout—Set the time in seconds you want to use for the debug timeout. This is the time allowed before the Oracle® Enterprise Session Border Controller times out log levels for system processes set to debug using the ACLI notify and debug commands.
This command does not affect log levels set in your configuration (using parameters such as system-config>process-log-level) or those set using the ACLI log-level command.
