Configure Public Settings
To set a public setting on the Oracle® Enterprise Session Border Controller (E-SBC):
Type
http-alg-public and press Enter.
ACMEPACKET(http-alg)# http-alg-public ACMEPACKET(http-alg-public)#The public side (outside the network) is used to receive incoming HTTP SOAP Requests from the remote worker. You define the IP address, port, and TLS certificate used to establish a connection with the remote worker by setting this http-alg-public attribute.
- realm-id—Name of the realm that the E-SBC uses to listen for the HTTP request. Valid values are alpha-numeric characters. Default is blank.
- address—IPv4 or IPv6 IP address on which the E-SBC is listening for HTTP traffic. Valid values must be in the format of 0.0.0.0. Default is blank.
- port—Port on which the E-SBC is listening for HTTP traffic. Valid values are 1 to 65535. Default is 80.
- tls-profile—The TLS profile used to establish a secure connection with the remote worker. Setting this attribute enables HTTP proxy to listen for HTTPS traffic. Valid values are alpha-numeric characters. Default is blank.
Type
done and press Enter.
ACMEPACKET(http-alg-public)# done ACMEPACKET(http-alg-public)# -
Type
exit and press Enter.
ACMEPACKET(http-alg-public)# exit ACMEPACKET(http-alg)# -
Type
ACMEPACKET(http-alg)# exit ACMEPACKET(session-router)# - Save the configuration.
