Configuring Routing
This section explains how to configure routing on the Oracle® Enterprise Session Border Controller.
Configuration Prerequisite
You should have already configured the realms for your environment before you configure the routing elements. You need to know the realm identifier when configuring session agents and local policy.
You can use an asterisk (*) when the session agent exists in multiple realms.
Configuration Order
Recommended order of configuration:
- realm
- session agent
- session agent group
- local policy
Routing Configuration
You can enable, then configure, individual constraints that are applied to the sessions sent to the session agent. These constraints can be used to regulate session activity with the session agent. In general, session control constraints are used for session agent groups or SIP proxies outside or at the edge of a network. Some individual constraints, such as maximum sessions and maximum outbound sessions are not applicable to core proxies because they are transaction stateful, instead of session stateful. Other constraints, such as maximum burst rate, burst rate window, maximum sustained rate, and sustained rate are applicable to core routing proxies.
Configuring Session Agents
To configure session agents:
In Superuser mode,
type
configure
terminal and press Enter.
ORACLE# configure terminal
Type
session-router and
press Enter to access the system-level configuration elements.
ORACLE(configure)# session-router
Type session-agent
and press Enter. The system prompt changes to let you know that you can begin
configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
host-name—Enter the
name of the host associated with the session agent in either hostname or FQDN
format, or as an IP address.
If you enter the host name as an IP address, you do not have to enter an IP address in the optional IP address parameter. If you enter the host name in FQDN format, and you want to specify an IP address, enter it in the optional IP address parameter. Otherwise you can leave the IP address parameter blank to allow a DNS query to resolve the host name.
If the initial DNS query for the session agent fails to get back any addresses, the session agent is put out-of-service. When session agent is pinged, the DNS query is repeated. The ping message is not sent until the DNS query gets back one or more IP addresses. After the query receives some addresses, the ping message is sent. The session agent remains out of service until one of the addresses responds.
The value you enter here must be unique to this session agent. No two session agents can have the same hostname.The hostnames established in the session agent populate the corresponding fields in other elements.
- ip-address—Optional. Enter the IP address for the hostname you entered in FQDN format if you want to specify the IP address. Otherwise, you can leave this parameter blank to allow a DNS query to resolve the host name.
port—Enter the
number of the port associated with this session agent. Available values
include:
zero (0)—If you enter zero (0), the Oracle® Enterprise Session Border Controller will not initiate communication with this session agent (although it will accept calls).
1025 through 65535
The default value is 5060.
If the transport method value is TCP, the Oracle® Enterprise Session Border Controller will initiate communication on that port of the session agent.
state—Enable or
disable the session agent by configuring the state. By default, the session
agent is
enabled.
enabled | disabled
app-protocol—Enter
the protocol on which you want to send the message. The default value is
SIP. Available
values are:
SIP | H.323
app-type—If
configuring H.323, indicate whether the application type is a gateway or a
gatekeeper. Available values include:
H.323-GW—gateway
H.323-GK—gatekeeper
transport-method—Indicate
the IP protocol to use (transport method) to communicate with the session
agent.
UDP is the default
value. The following protocols are supported:
UDP—Each UDP header carries both a source port identifier and destination port identifier, allowing high-level protocols to target specific applications and services among hosts.
UDP+TCP—Allows an initial transport method of UDP, followed by a subsequent transport method of TCP if and when a failure or timeout occurs in response to a UDP INVITE. If this transport method is selected, INVITEs are always sent through UDP as long as a response is received.
DynamicTCP—dTCP indicates that dynamic TCP connections are the transport method for this session agent. A new connection must be established for each session originating from the session agent. This connection is torn down at the end of a session.
StaticTCP—sTCP indicates that static TCP connections are the transport method for this session agent. Once a connection is established, it remains and is not torn down.
DynamicTLS—dTLS indicates that Dynamic TLS connections are the transport method for this session agent. A new connection must be established for each session originating from the session agent. This connection is torn down at the end of a session.
StaticTLS—sTLS indicates that Static TLS connections are the transport method for this session agent. Once a connection is established, it will remain and not be torn down.
realm-id—Optional.
Indicate the ID of the realm in which the session agent resides.
The realm ID identifies the realm for sessions coming from or going to this session agent. For requests coming from this session agent, the realm ID identifies the ingress realm. For requests being sent to this session agent, the realm ID identifies the egress realm. In a Oracle® Enterprise Session Border Controller, when the ingress and egress realms are different, the media flows must be steered between the realms.
no value: the egress realm is used unless the local policy dictates otherwise
asterisk (*): keep the egress realm based on the Request URI
The realm ID you enter here must match the valid identifier value entered when you configured the realm.
- description—Optional. Enter a descriptive name for this session agent.
carriers—Optional.
Add the carriers list to restrict the set of carriers used for sessions
originating from this session agent.
Carrier names are arbitrary names that can represent specific service providers or traditional PSTN telephone service providers (for sessions delivered to gateways). They are global in scope, especially if they are exchanged in TRIP. Therefore, the definition of these carriers is beyond the scope of this documentation.
You could create a list using carrier codes already defined in the North American Numbering Plan (NANP); or those defined by the local telephone number or carrier naming authority in another country.
If this list is empty, any carrier is allowed. If it is not empty, only local policies that reference one or more of the carriers in this list will be applied to requests coming from this session agent. -
allow-next-hop-lp—Indicate
whether this session agent can be used as a next hop in the local policy.
If you retain the default value of enabled, the session agent can be used as the next hop for the local policy. Valid values are:
enabled | disabled
constraints—Enable
this parameter to indicate that the individual constraints you configure in the
next step are applied to the sessions sent to the session agent. Retain the
default value of
disabled if you do
not want to apply the individual constraints. Valid values are:
enabled | disabled
In general, session control constraints are used for SAGs or SIP proxies outside or at the edge of a network.
Enter values for
the individual constraints you want applied to the sessions sent to this
session agent. The following table lists the available constraints along with a
brief description and available values.
maximum sessions Maximum number of sessions (inbound and outbound) allowed by the session agent. The range of values is: - minimum: zero (0) is the default value and means there is no limit
- maximum: 4294967295
maximum outbound sessions Maximum number of simultaneous outbound sessions (outbound from the Oracle® Enterprise Session Border Controller) that are allowed from the session agent. The range of values is: - minimum: zero (0) is the default value and means there is no limit
The value you enter here cannot be larger than the maximum sessions value.
maximum burst rate Number of session invitations allowed to be sent to or received from the session agent within the configured burst rate window value. SIP session invitations arrive at and leave from the session agent in intermittent bursts. By entering a value in this field, you can limit the amount of session invitations that are allowed to arrive at and leave from the session-agent. For example, if you enter a value of 50 here and a value of 60 (seconds) for the burst rate window constraint, no more than 50 session invitations can arrive at or leave from the session agent in that 60 second time frame (window). Within that 60-second window, any sessions over the limit of 50 are rejected.
- minimum: zero (0) session invitations per second
- maximum: 4294967295 session invitations per second
Zero is the is the default value.
maximum sustain rate Maximum rate of session invitations (per second) allowed to be sent to or received from the session agent within the current window. The current rate is determined by counting the number of session invitations processed within a configured time period and dividing that number by the time period. By entering a value in this field, you can limit the amount of session invitations that are allowed to arrive at and leave from the session agent over a sustained period of time. For the sustained rate, the Oracle® Enterprise Session Border Controller maintains a current and previous window size. The period of time over which the rate is calculated is always between one and two window sizes.
For example, if you enter a value of 5000 here and a value of 3600 (seconds) for the sustain rate window constraint, no more than 5000 session invitations can arrive at or leave from the session agent in any given 3600 second time frame (window). Within that 3600-second window, sessions over the 5000 limit are rejected.
- minimum: zero (0) invitations per second
- maximum: 4294967295 invitations per second
The value you set here must be larger than the value you set for the maximum burst rate constraint.
time to resume Time in seconds after which the SIP proxy resumes sending session invitations to this session agent. This value only takes effect when the SIP proxy stops sending invitations because a constraint is exceeded. The range of values is:
- minimum: zero (0) seconds
- maximum: 4294967295 seconds
Default is zero.
time to resume (ttr) no response Delay in seconds that the SIP proxy must wait from the time that it sends an invitation to the session agent and gets no response before it tries again. The range of values is:
Default is zero.
The value you enter here must be larger than the value you enter for the time to resume constraint.
in service period Amount of time in seconds the session agent must be operational (once communication is re-established) before the session agent is declared as being in-service (ready to accept session invitations). This value gives the session agent adequate time to initialize. The range of values is:
Default is zero.
burst rate window Burst window period (in seconds) that is used to measure the burst rate. The term window refers to the period of time over which the burst rate is computed. Refer to the maximum burst rate information. The range of values is:
- maximum: 4294967295seconds
The value you set here must be smaller than the value you set for the maximum burst rate constraint.
sustain rate window Sustained window period (in seconds) that is used to measure the sustained rate. Refer to the maximum sustain rate information. The range of values is:
The value you set here must be larger than the value you set for the maximum sustain rate constraint.
req-uri-carrier-mode—SIP
only. Set whether you want the selected carrier (determined by a value in the
local policy) added to the outgoing message by configuring the request uri
carrier mode parameter.
You can set this parameter to let the system perform simple digit translation on calls sent to gateways. A 3-digit prefix is inserted in front of the telephone number (the Request-URI) that the gateway will use to select a trunk group. Most often, the Oracle® Enterprise Session Border Controller needs to insert the carrier code into the signaling message that it sends on.
The default value is none. The following lists the available modes.
none—Carrier information will not be added to the outgoing message.
uri-param—Adds a parameter to the Request-URI. For example, cic-XXX.
prefix—Adds the carrier code as a prefix to the telephone number in the Request-URI (in the same manner as PSTN).
proxy-mode—SIP only.
Indicate the proxy mode to use when a SIP request arrives from this session
agent.
If this field is empty (upon initial runtime or upgrade), it’s value is set to the value of the SIP configuration’s proxy mode by default. If no proxy mode value was entered for the SIP configuration, the default for this field is proxy.
The following are valid proxy modes:
proxy—If the Oracle® Enterprise Session Border Controller is a Session Router, the system will proxy the request coming from the session agent and maintain the session and dialog state. If the Oracle® Enterprise Session Border Controller is a Session Director, the system behaves as a B2BUA when forwarding the request.
redirect—The system sends a SIP 3xx reDIRECT response with contacts (found in the local policy) to the previous hop.
redirect-action—SIP
only. Indicate the action you want the SIP proxy to take when it receives a
Redirect (3XX) response from the session agent.
If the response comes from a session agent and this field is empty (upon initial runtime or upgrade), the redirect action will be recurse. If no session agent is found (for example, if a message comes from an anonymous user agent), the redirect action is set to proxy. If the Redirect (3xx) response does not have any Contact header, the response will be sent back to the previous hop.
The following table lists the available proxy actions along with a brief description
proxy—The SIP proxy passes the response back to the previous hop; based on the pfoxy mode of the original request.
recurse—The SIP proxy serially sends the original request to the list of contacts in the Contact header of the response (in the order in which the contacts are listed in the response). For example, if the first one fails, the request will be send to the second, and so on until the request succeeds or the last contact in the Contact header has been tried.
loose-routing—SIP
only. Enable this parameter if you want to use loose routing (as opposed to
strict routing). The default is
enabled. Valid
values are:
enabled | disabled
When the SIP NAT route home proxy parameter is enabled, the Oracle® Enterprise Session Border Controller looks for a session agent that matches the home proxy address and checks the loose routing value. If loose routing is enabled, a Route header is included in the outgoing request in accordance with RFC 3261. If loose routing is disabled, the Route header is not included in the outgoing request (in accordance with strict routing procedures defined in RFC 2543).
The loose routing value is also checked when the local policy’s next hop value matches a session agent. If loose routing is set to enabled, the outgoing request retains the original Request-URI and Route header with the next hop address.
send-media-session—SIP
only. Enable this parameter if you want to include a media session description
(for example, SDP) in the INVITE or REINVITE message sent by the
Oracle® Enterprise Session Border Controller. Setting this field to
disabled prevents
the
Oracle® Enterprise Session Border Controller from establishing flows for that INVITE message.
The default is enabled. Valid values are:
enabled | disabled
Only set send media session to disabled for a session agent that always redirects requests. It returns an error or 3xx response instead of forwarding an INVITE message. In addition, do not disable send media session on session agents that support SIP-to-H.323 IWF call flows. This can cause call failure.
- response-map—Optional and for SIP only. Enter the name of the response map to use for this session agent. The mappings in each SIP response map is associated with a corresponding session agent. You can also configure this value for individual SIP interfaces.
ping-method—SIP
only. Indicate the SIP message/method to use to ping a session agent. The ping
confirms whether the session agent is in service. If this field is left empty,
no session agent will be pinged.
Setting this field value to the OPTIONS method might produce a lengthy response from certain session agents and could potentially cause performance degradation on your Oracle® Enterprise Session Border Controller.
ping-interval—SIP
only. Indicate how often you want to ping a session agent by configuring the
ping interval parameter. Enter the number of seconds you want the
Oracle® Enterprise Session Border Controller to wait between pings to this session agent. The
default value is
0. The valid range
is:
Minimum: 0
Maximum: 999999999
The Oracle® Enterprise Session Border Controller only sends the ping if no SIP transactions (have occurred to/from the session agent within the time period you enter here.
trunk-group—Enter up
to 500 trunk groups to use with this single session agent. Because of the high
number of trunk groups you can enter, the ACLI provides enhanced editing
mechanisms for this parameter:
You use a plus sign (+) to add single or multiple trunk groups to the session agent’s list.
When you add a single trunk group, simply use the plus sign (+) in front of the trunk group name and context. Do not use a Space between the plus sign and the trunk group name and context.
For example, you might have already configured a list of trunk groups with the following entries: tgrpA:contextA, tgrpB:contextB, and tgrpC:contextC. To add tgrp1:context1, you would make the following entry:
ORACLE(session-agent)# trunk-group +tgrp1:context1
Your list would then contain all four trunk groups.
When you add multiple trunk groups, simply enclose your entry in quotation marks () or in parentheses (()). While you put spaces between the trunk group name and context entries, you do not use spaces with the plus sign, parentheses or quotation marks.
ORACLE(session-agent)# trunk-group +tgrp1:context1 tgrp2:context2 tgrp3:context3 -
You use a minus sign (-) to delete single or multiple trunk groups from the session agent’s list.
When you remove a single trunk group, simply use the minus sign (-) in front of the trunk group name and context. Do not use a Space between the minus sign and the trunk group name and context.
For example, you might have already configured a list of trunk groups with the following entries: tgrpA:contextA, tgrpB:contextB, tgrpC:contextC, and tgrp1:context1. To delete tgrp1:context1 from the list, you would make the following entry:
ORACLE(session-agent)# trunk-group -tgrp1:context1
Your list would then contain: tgrpA:contextA, tgrpB:contextB, and tgrpC:contextC.
When you add multiple trunk groups, simple enclose your entry in quotation marks () or in parentheses (()). While you put spaces between the trunk group name and context entries, you do not use spaces with the plus sign, parentheses or quotation marks.
ORACLE(session-agent)# trunk-group -tgrp1:context1 tgrp2:context2 -
You overwrite (replace) the entire list of a session agent’s trunk groups by entering a list that does not use either the plus (+) or the minus (-) sign syntax.
- ping-in-service-response-codes—SIP only. Enter the list of response codes that keep a session agent in service when they appear in its response to the Oracle® Enterprise Session Border Controller’s ping request. The Oracle® Enterprise Session Border Controller takes the session agent out of service should a response code be used that does not appear on this list. Default is none.
- out-service-response-codes—SIP only. Enter the list defines the response codes that take a session agent out of service when they appear in its response to the Oracle® Enterprise Session Border Controller’s ping request or any in-dialog creating request (such as an INVITE, SUBSCRIBE, etc.). The Oracle® Enterprise Session Border Controller ignores this list if an in-service list exists.
options—Optional.
You can add your own features and/or parameters by using the options parameter.
You enter a comma-separated list of either or both of the following:
feature=<value feature>
For example:
You can include the original address in the SIP message from the Oracle® Enterprise Session Border Controller to the proxy in the Via header parameter by entering the following option:
via-origin=<parameter-name>
The original parameter is included in the Via of the requests sent to the session agent. The via origin feature can take a value that is the parameter name to include in the Via. If the value is not specified for via origin, the parameter name is origin.
If the feature value itself is a comma-separated list, enclose it within quotation marks. -
media-profiles—Optional
and for H.323 only. You can enter a list of media profiles to open logical
channels when starting an outgoing call as a Fast Start H.323 call.
Values you enter here must start with either an alphabetical character from A through Z (A-Za-z) or with an underscore (_). After the first character, each list entry can contain any combination of alphabetical or numerical characters (0-9A-Za-z), as well as the period (.), the dash (-), and the underscore (_). For example, netnet_mediaprofile1.
You can enter 1 to 24 characters.
The values you enter here must correspond to a valid name you entered when you configure the media profile. - in-translationid—Optional. Enter the In Translation ID for a configured session translation (group of address translation rules with a single ID) if you want to apply session translation to incoming traffic.
out-translationid—Optional.
Enter the Out Translation ID for a configured session translation (group of
translation to outgoing traffic.
Address translations attached to session agents take precedence over address translations attached to realms. If no address translation is applied to a session agent, then the Oracle® Enterprise Session Border Controller will use the address translation applied to a realm. If an address translation is applied to both a realm and session agent, the translation attached to the session agent will apply. If the applicable session agent and realm have no associated translations, then the addresses will remain in their original forms and no address translations will be performed.
trust-me—Indicate
whether this session agent is a trusted source, which the
Oracle® Enterprise Session Border Controller checks when it receives a message to determine if the
source is trusted. The default value is
disabled. The valid
values are:
enabled | disabled
The following example shows a session agent with an IP address used for the hostname.
session-agent hostname 192.168.1.10 ip-address 192.168.1.10 port 5060 state enabled app-protocol SIP app-type transport-method UDP realm-id realm-1 description englab carriers carrier1 allow-next-hop-lp enabled constraints disabled max-sessions 355 max-inbound-sessions 4 max-outbound-sessions 355 max-burst-rate 0 max-inbound-burst-rate 10 max-outbound-burst-rate 1 max-sustain-rate 3000 max-inbound-sustain-rate 0 max-outbound-sustain-rate 0 min-seizures 5 min-asr 0 time-to-resume 60 ttr-no-response 0 in-service-period 30 burst-rate-window 60 sustain-rate-window 3600 req-uri-carrier-mode None proxy-mode Proxy redirect-action Recurse loose-routing enabled send-media-session enabled response-map ping-method ping-interval 0 media-profiles in-translationid out-translationid trust-me disabled request-uri-headers stop-recurse local-response-map ping-to-user-part ping-from-user-part li-trust-me disabled in-manipulationid out-manipulationid p-asserted-id trunk-group max-register-sustain-rate 0 -
Session Agent Group Configuration
To configure session agent groups:
Access the
session-agent-group configuration element.
ORACLE# configure terminal ORACLE(configure)# session-router ORACLE(session-router)# session-group ORACLE(session-agent-group)#
- group-name—Enter a unique name for the session agent group in Name format.
- description—Optional. Enter descriptive information about the session agent group.
state—Enable or disable the session agent group on the
Oracle® Enterprise Session Border Controller. The default value is
enabled | disabled
application-protocol—Indicate the signaling protocol you want to use with the session agent group. The default value is
SIP. The valid values are:
SIP | H.323
strategy—Indicate the session agent allocation strategy you want to use. The strategy you chose selects the session agents that will be made available by this session agent group. The default value is
hunt. The valid values are:
hunt—Selects session agents in the order in which they are listed. For example, if the first agent is online, working, and has not exceeded defined constraints, all traffic is sent to the first agent. If the first agent is offline or if it exceeds a defined constraint, the second agent is selected. If the first and second agents are offline or exceed defined constraints, the third agent is selected. And so on through the list of session agents.
roundrobin—Selects each session agent in the order in which they are listed in the destination list, selecting each agent in turn, one per session.
leastbusy—Selects the session agent that has the fewest number of sessions relative to the maximum sessions constraint (for example, lowest percent busy) of the session agent element. The Least Busy Calculation is the result of dividing the number of active calls for a session agent by the max-sessions parameter within the session-agent element configuration. If the default max-session parameter value issued for a session agent (0), the result of the Least Busy Calculation will be 0. The Least Busy SAG Strategy will route a session to the session agent with the lowest resulting Least Busy Calculation percentage. If multiple session agents have the lowest percentage, the foremost session agent in the Session Agent Group dest parameter will be used.
propdist—Based on programmed, constrained session limits, the Proportional Distribution strategy proportionally distributes the traffic among all of the available session agents. Sessions are distributed among session agents based on the max-outbound-sessions value in each session agent. The sum of max-outbound-sessions for every session-agent within a session group equates to 100% and the max-outbound-sessions value for each session-agent represents a % that total. Sessions are proportionally allocated to session agents based on their individual session agent max-outbound-sessions value, as a % of the total max-outbound-sessions for the group.
lowsusrate—The Lowest Sustained Rate strategy routes to the session agent with the lowest sustained rate of session initiations/invitations (based on observed sustained session request rate).
destination—Identify the destinations (session agents) available for use by this session agent group.
A value you enter here must be a valid IP address or hostname for a configured session agent.
trunk-group—Enter trunk group names and trunk group contexts to match in either IPTEL or custom format. If left blank, the
Oracle® Enterprise Session Border Controller uses the trunk group in the realm for this session agent group. Multiple entries are surrounded in parentheses and separated from each other with spaces.
Entries for this list must one of the following formats: trgp:context or trgp.context.
sag-recursion—Enable this parameter if you want to use SIP SAG recursion for this SAG. The default value is
disabled. Valid values are:
enabled | disabled
stop-sag-recurse—Enter the list of SIP response codes that terminate recursion within the SAG. Upon receiving one of the specified response codes, such as 401 unauthorized, or upon generating one of the specified response codes internally, such as 408 timeout, the
Oracle® Enterprise Session Border Controller returns a final response to the UAC and stops trying to route the message. This includes not attempting to contact higher-cost SAs.
You can enter the response codes as a comma-separated list or as response code ranges.
- Type done to save your configuration.
SAG Matching for LRT and ENUM
When this feature is enabled and a match is found, the Oracle® Enterprise Session Border Controller uses the matching SAG for routing. When there is no match for the SAG, the Oracle® Enterprise Session Border Controller processes the result as it would have if this feature had not been enabled: either matching to a session agent hostname, or performing a DNS query to resolve it.
Note that you set the state of this feature in the SIP configuration.
To configure a SAG for ENUM or LRT matching:
In Superuser mode, type
configure terminal and press Enter.
Type
session-router and press Enter to access the signaling-level configuration elements.
Type
sip-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
If you are adding support for this feature to a pre-existing SIP configuration, then you must select (using the ACLI select command) that configuration to edit it.
enum-sag-match—Set this parameter to enabled so the
Oracle® Enterprise Session Border Controller will match session agent group (SAG) names with the hostname portion in the naming authority pointer (NAPTR) from an ENUM query or LRT next-hop entry. The default value is
disabled. The valid values are:
enabled | disabled
- Save and activate your configuration.
Configuring Local Policy
To configure local policy:
ACMEPACKET# configure terminal -
Type
session-router and press Enter.
ACMEPACKET(configure)# session-router -
Type
local-policy and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ACMEPACKET(session-router)# local-policy ACMEPACKET(local-policy)# -
from-address—Indicate the originating address information by entering a From address value. You can use the asterisk (*) as a wildcard to indicate this policy can be used with all originating addresses.
You can also use complete or partial E.164 addresses (strings that contain telephone keypad characters) here. Number matching works from left to right. Formats include the following:
SIP From address
FQDNs
IP addresses
H.323 CallingPartyAddress
The Oracle® Enterprise Session Border Controller also supports the asterisk as part of the From address you configure in your local policies.
This means that for the from-address parameters of a local policy configuration, you can enter values in which an asterisk appears and match them accordingly. You might enter a value that resemble the following example:
123*456
After entering the from-address value, the Oracle Communications Session Delivery Manager automatically saves it to the configuration when exiting from local policy. -
to-address—Indicate the destination address by entering a To address value. You can use the asterisk (*) as a wildcard to indicate all this policy can be used for any destination address.
You can also use E.164 addresses (strings that contain telephone keypad characters) here. Number matching works from left to right. Formats include the following:
SIP Request-URI
FQDNs
IP addresses
H.323 CalledPartyAddress
The system also supports the asterisk as part of the To address you configure in your local policies.
This means that for the to-address parameters of a local policy configuration, you can enter values in which an asterisk appears and match them accordingly. You might enter a value that resembles the following example:
123*456
After entering the to-address value, the Oracle Communications Session Delivery Manager automatically saves it to the configuration when exiting from local policy. -
source-realm—Enter the realm, or list of realms, you want the
Oracle® Enterprise Session Border Controller to use to determine how to route traffic. This list identifies from what realm traffic is coming and is used for routing by ingress realm by the local policy.
You can use the asterisk (*) as a wildcard to indicate this local policy can be used with all realms. The default value is *.Or you can enter a value that corresponds to the identifier of an already configured realm. Formats include the following:
realm ID
customer name
peer name
subdomain name
VPN identifier
activate-time—Set the time you want the local policy to be activated using the following syntax:
yyyy:mm:dd hh:mm:ss yyyy:mm:dd-hh:mm:ss
deactivate-time—Set the time you want the local policy to be deactivated using the following syntax:
state—Indicate whether you want the local policy to be enabled or disabled on the system. The default value is
enabled. The valid values are:
enabled | disabled
- policy-attribute—Configure local policy attributes by following steps 8 through 21.
next-hop—Identify the next signaling host by entering the next hop value. You can use the following as next hops:
IPv4 address or IPv6 address of a specific endpoint
Hostname or IPv4 address or IPv6 address of a configured session agent
Group name of a configured session agent group
The group name of a configured session agent group must be prefixed with SAG:For example:
policy-attribute
next-hop SAG:appserver
policy-attribute
next-hop lrt:routetable
policy-attribute
next-hop enum:lerg
You can also configure a next hop that has an address of 0.0.0.0, thereby creating a null route. Different from not having a local policy configured (which would trigger Oracle® Enterprise Session Border Controller local policy recursion), this terminates local policy recursion and immediately fails the request. In these cases, the system responds a request with a 404 Not Found.
realm—Identify the egress realm (the realm used to reach the next hop) if the system must send requests out from a specific realm.
The value you enter here must correspond to a valid identifier you enter when you configured the realm. If you do not enter a value here, and the next hop is a session agent, the realm identified in the session agent configuration is used for egress. In H.323, the next hop address is matched against the realm’s address prefix to determine the realm.
- replace-uri—Indicate whether you want to replace the Request-URI in outgoing SIP requests with the next hop value.
carrier—Optional. Enter the name of the carrier associated with this route. The value you enter here must match one or more of the carrier names in the session agent configuration.
Entries in carrier fields can be from 1 to 24 characters in length and can consist of any alphabetical character (Aa-Zz), numerical character (0-9), or punctuation mark (! ” # $ % ^ & * ( ) + - = < > ? ‘ | { } [ ] @ / \ ‘ ~ , . _ : ; ) or any combination of alphabetical characters, numerical characters, or punctuation marks. For example, both 1-0288 and acme_carrier are valid carrier field formats.
start-time—Indicate the time of day (from the exact minute specified) the local policy attributes go into effect. Enter only numerical characters (0-9) and follow the 4-digit military time format. For example:
1400
The default value of 0000 implies that the defined policy attributes can be considered in effect any time after 00:00:00. The valid range is:
Minimum—0000
Maximum—2400
end-time—Indicate the time of day (from the exact minute specified) the local policy attributes are no longer in effect. Enter only numerical characters (0-9) and follow the 4-digit military time format. For example:
2400
The default value of 2400 implies that the defined policy attributes can be considered in effect any time before midnight. The valid range is:
Minimum—0000
Maximum—2400
days-of-week—Enter any combination of days of the week (plus holidays) you want the local policy attributes to be in effect. You must enter at least one day or holiday here. A holiday entry must correspond with a configured holiday established in the Session Router.
The default is U-S. The valid values are:
U (Sunday)
M (Monday)
T (Tuesday(
W (Wednesday)
R (Thursday)
F (Friday)
S (Saturday)
H (Holiday)
You can enter a range of values separated by a hyphen, for example U-S. And you can enter multiple values separated by commas, for example M,W,F. You cannot use spaces as separators.
cost—Enter a cost value that acts as a unitless representation of the cost of a route relative to other routes reaching the same destination (To address). This value is used as a way of ranking policy attributes.
The default value is zero (0). The valid values are:
minimum—zero (0)
maximum—999999999
app-protocol—Enter the signaling protocol to use when sending messages to the next hop. The valid values are:
H.323 | SIP
state—Indicate whether you want to enable or disable the local policy. The default value is
enabled | disabled
media-profiles—Configure a list of media profiles if you want the local policy to route SIP and H.323 traffic by the codecs specified in the SDP. The list of media profiles entered here are matched against the SDP included in SIP or H.323 requests and the next hop is selected by codec.
The values in this list are matched against the rtpmap attribute of passed SDP, and preference weight for route selection is based on the order in which the matching payload type appears in the SDP’s media (m=) line.
For example when the following SDP arrives:
m=audio 1234 RTP/AVP 0 8 18
that contains the following attributes that correspond to three configured local policies with the same cost:
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
the following route selection action occurs:
The local policy route that corresponds to the a=rtpmap:0 PCMU/8000 attribute is selected because the payload type of 0 in the attribute line matches the first payload type of 0 listed in the m= line. The codec value of PCMU indicated in this selected attribute is used to find the local policy with the media profiles attribute that includes PCMU in the list.
Because the value you enter here is matched against the codec values included in the actual passed SDP, it must correspond to accepted industry-standard codec values.
The following example shows a local policy with a next hop value of the session agent group called gw-sag2.
local-policy from-address * to-address 192.168.1.10 source-realm * activate-time 2005-01-20 20:30:00 deactivate-time N/A state enabled last-modified-date 2005-01-10 00:36:29 policy-attribute next-hop SAG:gw-sag2 realm replace-uri enabled carrier start-time 0000 end-time 2400 days-of-week U-S cost 0 app-protocol state enabled media-profiles
Local Policy Matching for Parent Realms
For SIP and H.323, you can configure the Oracle® Enterprise Session Border Controller to use the parent realm for routing purposes even when the source realm for an incoming message is a child realm.
With this feature disabled (default), the Oracle® Enterprise Session Border Controller uses the specific source realm to perform a local policy look-up. When the source realm is a child realm and any relevant local policies are configured with the parent realm, there will be no matches and the local policy look-up will fail. To avoid this issue and ensure successful look-ups, you must configure multiple local policies if you want to use a configuration with nested realms.
The Oracle® Enterprise Session Border Controller examines the source realm to determine if it is a parent realm with any child realms when you enable this feature. If the parent, source realm does have child realms, then the Oracle® Enterprise Session Border Controller creates local policy entries for the parent and all of its child realms. This operation is transparent and can save time during the configuration process.
It is possible, then, for a local policy look-up to match the same child realm in two ways:
- Through a match via the parent realm
- Through a direct match for a local policy configured with that specific child realm
In such a case, the child realm must have different costs for each type of match to avoid collisions.
This feature is enabled on a global basis in the session router configuration. Because it applies system-wide, all source realms will use this form of matching when enabled.
To enable local policy matching for parent realms:
Type
session-router
and press Enter to access the signaling-related configurations.
Type
session-router
and press Enter.
ORACLE(session-router)# session-router ORACLE(session-router-config)#
match-lp-source-parent-realms—If you want the
Oracle® Enterprise Session Border Controller to perform local policy realm matching based on the parent realm (so that there are local policy entries for parent and child realms), set this parameter to
enabled. The default value is
enabled | disabled
ORACLE(session-router-config)# match-lp-src-parent-realms enabled
