Fraud Prevention Configuration
To set a maximum SIP message size:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the signaling-level configuration elements.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
sip-config and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# sip-config ORACLE(sip-config)#
Type
select to configure the existing sip config.
ORACLE(sip-config)# select
sip-message-len—Set the size constraint in bytes of a SIP message. The default is
4096. The valid range is:
Minimum—0
Maximum—65535
This completes the configuration.
ORACLE(sip-config)# sip-message-len 5000
- Save your work using the ACLI done command.
