Media Release Behind the Same NAT IP Address
You can now configure your Oracle® Enterprise Session Border Controller to release media between endpoints sharing the same NAT IP address, even if one endpoint is at—but not behind—the same NAT. This feature expands on the Oracle® Enterprise Session Border Controller’S pre-existing ability to release media between calling and called parties behind the same IP address/NAT device in the same realm or network.
Media Release Configuration
For this feature to work properly, your realm configuration should either have the mm-in-realm or mm-in-network parameter set to disabled, unless the mm-same-ip parameter is set to disabled. If the mm-same-ip parameter is enabled, then mm-in-realm or mm-in-network can both be enabled.
To set the option that enables media release behind the same IP address:
