Pre-Requisites
The Local Playback SPL plug-in is installed in the software, and you must fulfill the following requirements for Local Playback to work properly.
- Configure one or more playback configuration elements. See, Setting up the Playback Configuration.
- Configure the realm, session agent, or SIP interface objects with the necessary SPL playback option(s) for your deployment. See Setting Playback Options on Realms Session Agents and SIP Interfaces.
