PreviousNextJavaScript must be enabled to correctly display this content
SIP maddr Resolution Configuration
To configure the
Oracle® Enterprise Session Border Controller to perform SAG-based maddr resolution:
From superuser mode, use the following command sequence to access sip-config configuration mode. While in this mode, you configure SAG-based address resolution.
