Playback Configuration Example The following is an example of a playback configuration: playpback-config name Ringback entries encoding PCMU filename tonePCMU.rbf bytes-per-second 8000 entries encoding PCMA filename tonePCMA.rbf bytes-per-second 8000 entries encoding G729 filename toneG729.rbf bytes-per-second 8000
