Configure the Web Server From the ACLI
You must configure and enable the Web server for Oracle® Enterprise Session Border Controller (E-SBC) operations before you can use the Web GUI.
If you previously ran the Set Initial Configuration wizard from the Web GUI, confirm whether or not the Web GUI is already enabled.
The following procedure provides instructions to configure and enable the Web server through the ACLI.
The Web GUI supports only IPv4.To configure the Web server:
