Multiple Custom Filter Examples
The following examples show three custom filters (FILTER1, FILTER2, and FILTER3) created for SIP Monitor and Trace on the Net-Net ESD.
- Filter 1
ACMEPACKET(filter-config)# name FILTER1 ACMEPACKET(filter-config)# address 1.1.1.1 ACMEPACKET(filter-config)# user 5551212
- Filter 2
ACMEPACKET(filter-config)# name FILTER2 ACMEPACKET(filter-config)# address 3.3.3.3/24 ACMEPACKET(filter-config)# user 1781
- Filter 3
ACMEPACKET(filter-config)# name FILTER3 ACMEPACKET(filter-config)# user sip
You can specify the Net-Net ESD monitoring process to use FILTER1, FILTER2, and/or FILTER3 for global monitoring, or for monitoring SAs and/or realms. However, before you apply the custom filters, you can enable/disable SIP monitoring on the Net-Net ESD.
To enable/disable SIP monitoring, see Enabling Disabling SIP Monitoring & Tracing. To use a custom filter(s) on a global basis, see Using Filters to Monitor on a Global-Basis. To use a custom filter(s) when monitoring SAs, see Using Filters when Monitoring Session Agents. To use a custom filter(s) when monitoring realms, see Using Filters when Monitoring Realms.
