Enable and Disable SIP Monitor and Trace
You can enable or disable the Oracle® Enterprise Session Border Controller (E-SBC) to perform SIP monitoring using the state parameter at the path Configure terminal, session-router, sip-monitoring.
Use the following procedure to enable and disable SIP monitoring on the E-SBC.
You must enable the sip-monitoring object for monitoring and filtering to occur on the E-SBC. With sip-monitoring enabled, you can configure a filter on a global basis, as well as for a session agent or a realm. You can also initiate dynamic filter commands.To enable and disable sip-monitoring:
Configure global filters, or assign filters to a session agent and
realm. For more information, see the following:
With sip-monitoring enabled, you can also initiate dynamic filter commands if required. For more information about dynamic filter commands, see Dynamic Filter Commands.
