Enable Anonymization in a SIP INVITE Message
When
you want to hide certain sensitive information in a SIP INVITE message that the
Oracle Communications Operations Monitor (OCOM) can display, you can configure
the
Oracle® Enterprise Session Border Controller (E-SBC) to
anonymize the SUBJECT header in the message and in the CPIM body, as well as
the MIME content of the CPIM body with the
anonymize-invite option.
The default setting for the anonymize-invite option is disabled. Use
the options parameter in the comm-monitor configuration to enable
anonymize-invite.
Enabling the anonymize-invite option adds an additional CPU load to the E-SBC. Contact Oracle Customer Support for more information.- Select the comm-monitor instance that you want to enable for anonymization.
- Go to the options parameter, type anonymize-invite, and press ENTER.
- Save and exit the configuration.
