Deprecated Features
Oracle recommends that you review the following information about deprecated features and functions before using the E-CZ8.1.0 release
New Deprecations
| Feature | Description | Release Deprecated |
| Ciphers |
E-CZ8.1.0 |
| apEnvMonVoltageStatusEntry MIB object | The apEnvMonVoltageStatusEntry objects have been deprecated. Voltage monitoring is still available using the command in the ACLI. | S-Cz8.1.0m1p6 |
Previous Deprecations
| Platforms | The E-CZ8.1.0 release does not support either the Acme packet 3820 or the Acme Packet 4500. | E-CZ8.0.0 |
| Telnet |
Telnet is not supported. Use SSH for network access to E-SBC management. Note that references to Telnet and FTP are still present in the E-CZ8.1.0 documentation set because those terms are still used in the ACLI. For example, the telnet-timeout parameter persists in the guide because it persists in system-config where the parameter now specifies the SSH timeout. |
E-CZ7.5.0 |
