TLS Cipher Updates
Note the following changes to the DEFAULT cipher list.
Oracle recommends the following ciphers, and includes them
in the DEFAULT cipher list:
- TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_DHE_RSA_WITH_AES_256_CBC_SHA256
- TLS_DHE_RSA_WITH_AES_128_GCM_SHA256
- TLS_DHE_RSA_WITH_AES_128_CBC_SHA256
- TLS_RSA_WITH_AES_256_CBC_SHA256
- TLS_ECDHE_ECDSA_WITH_AES_128_GCM_SHA256
The following ciphers have been added and included in the DEFAULT cipher
list in CZ810m1p6:
- TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384
- TLS_ECDHE_RSA_WITH_AES_128_GCM_SHA256
- TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384
- TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256
Oracle supports the following ciphers, but does not include them in the
- TLS_RSA_WITH_AES_256_GCM_SHA384
- TLS_RSA_WITH_AES_128_GCM_SHA256
- TLS_RSA_WITH_AES_128_CBC_SHA
- TLS_RSA_WITH_3DES_EDE_CBC_SHA
Oracle supports the following ciphers for debugging purposes only:
- TLS_RSA_WITH_NULL_SHA256 (debug only)
- TLS_RSA_WITH_NULL_SHA (debug only)
- TLS_RSA_WITH_NULL_MD5 (debug only)
Oracle supports the following ciphers, but considers them not secure.
They are not included in the DEFAULT cipher-list, but they are included when
you set the
cipher-list
attribute to
ALL. Note that they
trigger
verify-config error
messages.
- TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
To configure TLS ciphers, use the cipher-list attribute in the tls-profile configuration element.
WARNING:
When you set tls-version to either tlsv1 or tlsv11 and you want to use ciphers that Oracle considers not secure, you must manually add them to the cipher-list attribute.
