Settings Button
Use the Settings button to access the following configuration elements.
| SBC Host Name | Name the session border controller host. |
| Description | Describe the session border controller host. |
| Location | Specify the location of the session border controller host. |
| Default Gateway IP Address | Specify the gateway IP address for the host. |
| NTP IP Address | Specify the IP address of the Network Time Protocol server. |
| Enable restart on critical failure | Enable automatic system restart after a critical failure. |
| Logging Settings | Specify the Syslog server and the process log level. |
| SNMP Settings | Enable SNMP traps and specify the MIB system. |
| SIP Settings | Configure SIP and add SIP options. |
| Denial of Service Settings | Specify packet rate settings for Denial of Service protection. |
| Communications Monitoring Probe Settings | Enable the Communications Monitoring Probe and specify the collector. |
| High Availability Settings | Enable High Availability and specify the peers. |
| Packet Capture Settings | Enable packet capture and specify the receiver. |
| Survivability | Enable remote site survivability and specify the triggering device. |
Configure Logging Settings
The Oracle® Enterprise Session Border Controller (E-SBC) generates SysLogs and process logs. You must configure the IP address for the SysLog server and the process log level for the process logs.
- Note the IP address of the Syslog server.
- Confirm that the system displays the Basic mode.
The Web GUI displays the logging configuration parameters on the Settings page. Use the following procedure to specify the Syslog server and to select a process log level.
Simple Network Management Protocol
Simple Network Management Protocol (SNMP) supports the monitoring of devices attached to the network for conditions that might need administrative attention.
- SNMP settings. Specifies the MIB contact information and enables event SNMP traps. See "Configure SNMP Settings."
- SNMP community. Specifies how certain E-SBC events are reported. See "Configure SNMP Community."
- Trap receiver. Specifies the trap receiver settings, including filters. See "Configure an SNMP Trap Receiver."
Logging Settings
You can configure the Oracle® Enterprise Session Border Controller (E-SBC) to generate Syslogs for system management and Process logs for debugging.
The E-SBC generates the following types of logs.
- Syslogs conform to the standard used for logging servers and processes as defined in RFC 3164. In configuration, you specify the Syslog server.
- Process logs are proprietary Oracle logs that the system generates on a per-task basis and are used mainly for debugging purposes. Because process logs are more data inclusive than Syslogs, their contents usually include Syslog log data. In configuration, you specify the log level.
Syslog and process log servers are both identified by an IPv4 address and port pair.
Simple Network Management Protocol (SNMP) is used to support the monitoring of devices attached to the network, such as the Oracle® Enterprise Session Border Controller (E-SBC), for conditions that warrant administrative attention.
The Web GUI displays the SNMP settings configuration parameters on the Settings page. Use the following procedure to configure MIB settings and to enable SNMP for the E-SBC.
SIP Settings
Session Initiation Protocol (SIP) is an IETF-defined signaling protocol widely used for controlling communication sessions such as voice and video calls over Internet Protocol (IP). The protocol can be used for creating, modifying and terminating two-party (unicast) or multiparty (multicast) sessions. Sessions may consist of one or several media streams.
Dialog Transparency
Dialog transparency prevents the Oracle® Enterprise Session Border Controller (E-SBC) from generating a unique Call-ID and modifying dialog tags. With dialog transparency enabled, the E-SBC is prevented from generating a unique Call-ID and from modifying the dialog tags. The Oracle® Enterprise Session Border Controller passes what it receives. When a call made on one E-SBC is transferred to another UA and crosses a second E-SBC, the second E-SBC does not note the context of the original dialog, and the original call identifiers are preserved end to end. The signalling presented to each endpoint remains in the appropriate context regardless of how many times a call crosses through a E-SBC or how many E-SBCs a call crosses.
Without dialog transparency enabled, the E-SBC SIP B2BUA rewrites the Call-ID header and inserted dialog cookies into the From and To tags of all messages it processes. These dialog cookies are in the following format: SDxxxxxNN-. Using these cookies, the E-SBC can recognize the direction of a dialog. However, this behavior makes call transfers problematic because the Call-ID of one E-SBC might not be properly decoded by another E-SBC. The result is asymmetric header manipulation and unsuccdessful call transfers.
IPv6 Reassembly and Fragmentation Support
As it does for IPv4, the E-SBC supports reassembly and fragmentation for large signaling packets when you enable IPV6 on the system.
The E-SBC takes incoming fragments and stores them until it receives the first fragment containing a Layer 4 header. With that header information, the E-SBC performs a look-up so it can forward the packets to its application layer. Then the packets are re-assembled at the applications layer. Media fragments, however, are not reassembled and are instead forwarded to the egress interface.
On the egress side, the E-SBC takes large signaling messages and encodes it into fragment datagrams before it transmits them.
Note that large SIP INVITE messages should be sent over TCP. If you want to modify that behavior, you can use the SIP interface’s option parameter max-udplength=xx for each SIP interface where you expect to receive large INVITE packets.
Other than enabling IPv6 on your E-SBC, there is no configuration for IPv6 reassembly and fragmentation support. It is enabled automatically.
Configure SIP Settings
Use the Settings button to access the SIP settings configuration section of the Settings page.
Use the following procedure to configure global SIP settings and options.
- Configure SIP Features.
Denial of Service Protection
The Oracle® Enterprise Session Border Controller (E-SBC) Denial of Service (DoS) protection functionality protects soft switches and gateways with overload protection, dynamic and static access control, and trusted device classification and separation in layers 3-5.
DoS protection prevents the E-SBC host processor from being overwhelmed by a targeted DoS attack from the following:
- IP packets from an untrusted source, as defined by provisioned and dynamic ACLs
- IP packets for unsupported and disabled protocols
- Nonconforming and malformed packets to signaling ports
- Volume-based attack of valid and invalid call requests, signaling messages, and so on.
The Server Edition and VM Edition support of DoS protection differs from the Oracle Hardware Platforms Edition due to the absence of Oracle network interface hardware. Consequently, DoS protection is implemented in software and consumes CPU cycles when responding to attacks.
The Server Edition and VM Edition handle media packet fragments differently, processing them in the data path rather than in the host application code. Protection against fragment attacks occurs because the system never keeps fragments for more than 5 milliseconds.
Configure Denial of Service Settings
Configure Denial of Service (DoS) settings to protect the Oracle® Enterprise Session Border Controller (E-SBC) from signal and media overload, while allowing legitimate, trusted devices to continue receiving service during an attack.
- Plan the maximum number of packets per second that you want for trusted packets, un-trusted packets, and ARP packets.
The Web GUI displays the denial of service configuration parameters on the Settings page. Use the following procedure to specify the settings that the system uses to calculate the trusted, untrusted, and ARP packets per second. Note that the configured rate is specified in packets per second, but the system measures the rate in packets per millisecond. For example, when the configured rate is 3200 packets per second, the actual measured rate is 3 packets per millisecond.
Communication Monitoring Probe Settings
Palladion is the Oracle Communication Experience Manager.
The manager is powered by the Palladion Mediation Engine, a platform that collects SIP, DNS, ENUM, and protocol message traffic received from Palladion Probes. The mediation engine stores the traffic in an internal database, and analyzes aggregated data to provide comprehensive multi-level monitoring, troubleshooting, and interoperability information.
Palladion simplifies the operation of software-based Palladion probes by enabling the transmission of Internet Protocol Flow Information Export (IPFIX) data to one or more Palladion Mediation Engines, possibly on different sub-nets.
The Palladion Communications Monitor Probe communicates over the media interface for signaling and Quality of Service (QoS) statistics using IPFIX. QoS reporting is done by way of Call Detail Records (CDR) accounting.Configure Communication Monitoring Probe Settings
Use the following procedure to establish a connection between the Oracle® Enterprise Session Border Controller (E-SBC) and the Palladion Mediation Engine. The E-SBC is the exporter of protocol message traffic and data and the Palladion Mediation Engine is the information collector.
- Confirm that the network interface that you want to monitor is configured.
The Web GUI displays the communication monitoring probe settings configuration parameters on the Settings page. Use the following procedure to enable ths function, and to specify the connection parameters.
You can deploy the Oracle® Enterprise Session Border Controller (E-SBC) in pairs to deliver High Availability (HA). Two E-SBCs operating in this way are called an HA node. Over the HA node, call state is shared, keeping sessions and calls from dropping in the event of a service disruption.
TwoE-SBCs work together in an HA node, one in active mode and one in standby mode.
- The active E-SBC checks itself for internal process and IP connectivity issues. If it detects that it is experiencing certain faults, it hands over its role as the active system to the standby E-SBC in the node.
- The standby E-SBC is the backup system, fully synchronized with the active E-SBCsession status. The standby E-SBC monitors the status of the active system so that, if needed, it can assume the active role without the active system having to instruct it to do so. If the standby system takes over the active role, it notifies network management using an SNMP trap.
To produce seamless switch overs from one E-SBC to the other, the HA node uses shared virtual MAC and virtual IP addresses for the media interfaces in a way that is similar to Virtual Router Redundancy Protocol (VRRP). Sharing addresses eliminates the possibility that the MAC and IPv4 address set on one E-SBC in an HA node will be a single point of failure. The standbyE-SBC sends ARP requests using a utility IPv4 address and its hard-coded MAC addresses to obtain Layer 2 bindings.
When there is a switch over, the standby E-SBC issues gratuitous ARP messages using the virtual MAC address, establishing that MAC on another physical port within the Ethernet switch. To the upstream router, the MAC and IP are still alive, meaning that existing sessions continue uninterrupted.
Within the HA node, the E-SBCs advertise their current state and health to one another in checkpointing messages; each system is apprised of the other’s status. Using Oracle’s HA protocol, the E-SBCs communicate with UDP messages sent out and received on the interfaces carrying "heartbeat" traffic between the active and standby devices.
The standby E-SBCassumes the active role when:
- It has not received a checkpoint message from the active E-SBC for a certain period of time.
- It determines that the active E-SBC’s health score has decreased to an unacceptable level.
- The active E-SBC relinquishes the active role.
High Availability on the Acme Packet 1100
The Acme Packet 1100 supports High Availability (HA), but the configuration differs from other Oracle® Enterprise Session Border Controllers (E-SBC) because there is only one management interface on this device.
Unlike other E-SBCs, which provide two management interfaces and two media interfaces, the Acme Packet 1100 provides 1 management interface and 2 media interfaces. For HA, you must create a second management interface object on the Acme Packet 1100 with wancom0 for the name and VLAN for the sub-port-id. You can configure only one management interface in an HA pair with these settings and the system does not support more than one HA interface with a VLAN tag.
The Acme Packet 1100 E-SBC does not support High Availability (HA) for any call using the Time Division Multiplexing (TDM) interface.Configure High Availability
To create a High Availability (HA) pair of Oracle® Enterprise Session Border Controllers (E-SBC), you must configure one E-SBC as the primary and the other E-SBC as the secondary.
The Web GUI displays the HA configuration parameters on the Settings page. Use the following procedure to create an HA pair and to establish communication between the devices.
Configure the Acme Packet 1100 Primary for HA
You can configure the Acme Packet 1100 primary for High Availability (HA) operations from the Web GUI by using the configuration tools in Basic mode.
- Confirm that the Oracle® Enterprise Session Border Controller software is installed on two separate systems.
You must perform the following procedure on the primary system before configuring the secondary system for HA operations.
Configure the secondary for High Availability. See "Configure the Acme Packet 1100 Secondary for High Availability (HA) - GUI Basic."
Configure the Acme Packet 1100 Secondary for HA
You can configure the Acme Packet 1100 secondary for High Availability (HA) operations from the Web GUI by using the configuration tools in Basic mode.
- Confirm that the Oracle® Enterprise Session Border Controller primary is configured for HA operations.
When configuring the secondary system, enter the same management interface VLAN that you entered for the primary system.
You can configure the packet capture function on the Oracle® Enterprise Session Border Controller (E-SBC) to view packet traffic on your network. For example, you might want to confirm the network configuration or to perform troubleshooting.
| Yes—Removes all existing files. | The system captures up to 25 new .pcap files. During the session, the system rotates the files in the /opt/traces directory by size. For example, the system keeps the last 25 files and rotates them when they reach 100 MB | |
| No—Keeps all existing files. |
Configure Packet Capture Settings
You can configure the Oracle® Enterprise Session Border Controller (E-SBC) to send packet captures to a designated receiver.
- Note the IP address and network interface of the device to which the E-SBC will send captured packets.
Use the following procedure to enable the packet capture function and to specify where the E-SBC sends the captured packets.
Remote Site Survivability
The remote site survivability feature enables an Oracle® Enterprise Session Border Controller (E-SBC) that is deployed in a Remote Office/Branch Office (ROBO) site to detect the loss of communication over SIP-based telephony to the Enterprise’s core call processing Data Center.
When loss of communication is detected over the SIP service, the ROBO E-SBC dynamically switches into Survivable Mode, handling call processing locally and providing limited additional server functionality.
Remote Site Survivability supports SIP only. It does not support H.323 call signalling.Remote Site Survivability:
- Works with or without High Availability (HA).
- Is configurable in real-time, with no reboot required to enable this feature.
- Allows configuration by way of the E-SBC Web GUI.
- Maintains Historical Recording (HDR) statistics about being in survivability mode, such as:
- Whether or not the E-SBC is in survivable mode using the ACLI command, show health.
- Length of time the E-SBC was in survivable mode (records the number of times and the amount of time in survivability mode).
- Number of SIP messages handled in survivable mode.
- Number of SIP users registered locally in survivable mode (both existing based on cache, and separately - new registrations).
Configure Remote Site Survivability
You must enable remote site survivability on the Oracle® Enterprise Session Border Controller (E-SBC) and set the parameters before the system can enter and exit survival mode.
- Confirm that at least one session is configured.
The Web GUI displays the Survivability configuration parameters on the Settings page, after you click Show advanced. Use the following procedure to enable ths function, specify a triggering device, and optionally change the default settings.
