File Management
You can manage system files from the Web GUI on the File Management page.
The following table describes the files that you can manage under File Management on the Oracle® Enterprise Session Border Controller (E-SBC).
| File Type | Format | Description |
| Backup configuration | .gz | File that contains a backup of the E-SBC software configuration. You can apply this file to restore a previous configuration if required. |
| Local route table (LRT) | .xml, .gz | Local routing table (LRT) file that you can apply to theE-SBC. The LRT is an in-memory table that contains IP addresses that the local router recognizes. It calculates the destinations of messages it is responsible for forwarding. |
| Fraud protection table | .gz, .gzip, .xml | Lists fraud protection files that you can upload, download, delete, or open to modify. |
| Log | Text |
Log files that contain information about the various aspects of the E-SBC. For example, information logged about the ACLI, SIP, or H323. Note: Only the Download and Delete functions are applicable to log files on the E-SBC. |
| Playback media | Any media format valid in an RTP audio stream |
Call progress playback files. The E-SBC can use these files in generated media streams if required. Note: The media files are raw binary files that contain data for the codec that a user wants to have played in the media stream. The E-SBC plays the data on the first audio flow in the Session Description Protocol (SDP). |
| Software Image | .gz, .bz | These files are bootable images. |
| SPL Plug-in | .lua | Session Plug-in Language (SPL) file that you can apply to the E-SBC to incorporate additional functionality. The SPL file contains a programming language that is capable of performing various tasks by utilizing APIs and callbacks in the E-SBC. |
The following table describes the file management buttons.
| Button | Description |
| Refresh | Updates the screen to display the latest data. |
| Upload | Uploads a file type from your server or PC to the E-SBC. The LRT, SPL, and backup configuration upload process provide the option of dynamically applying these files to the E-SBC. |
| Download | Downloads the file type from the E-SBC to your local server or PC (typically to the download directory on your system). Note: Download All applies only to log files. |
| Backup | Creates a file that contains a backup of the device software configuration. You can apply this file to restore a previous configuration. |
| Restore
(Applicable to the “Backup configuration” file type only.) |
Restores and applies a Backup configuration file to the E-SBC. |
| Delete | Deletes the file type from the E-SBC. Note: Delete All applies only to log files. |
Manage Files
You can activate an LRT file or an SPL file dynamically during an upload. You can also immediately apply a backup configuration file during the upload process.Group By Field
To customize the display of the File Management page on the System tab, you can group the elements by column head.
Upload a File
You can upload the following file types from your local server or PC to the Oracle® Enterprise Session Border Controller (E-SBC).
| File Type | File Format | Directory |
| Backup Configuration | .gz | /code/bkups |
| Local route table (LRT) | .xml, .gz | /code/gzConfig |
| Fraud protection table | .gz, .gzip, .xml | /code/fpe |
| Playback media | Any media format valid in an RTP audio stream | /code/media |
| Software image | .bz | /code/images |
| SPL Plug-on (SPL) | .lua | /code/spl |
The file extension must be applicable to the file type you select. For example, an SPL Plug-in file requires the .lua extension
You can dynamically activate the Local route table and SPL Plug-in during the upload process.
You can immediately restore a backup configuration file after an upload is complete.
You cannot upload log files.- From the Web GUI, click System, File management.
- On the File management page, from the File type drop down list, select the type of file you want to upload.
- In the Name column, select the file you want to upload.
- Click Upload.
In the Upload file
dialog, do the following:
- Click Browse.
- Select the file that you want to upload.
- Optional. For the Backup configuration file, select Restore the configuration after upload to apply a previous backed up configuration file immediately to the after the upload is complete.
- Optional. For the Local route table file type, select Activate the LRT file after upload to apply the LRT upon upload.
- Optional. For a Fraud protection file, select Activate the file after upload to apply the file upon upload.
- Optional. For the SPL Plug-in file type, select Activate the SPL file after upload to apply the SPL file upon upload.
- Click Upload.
Download a File
Procedure and conditions for downloading from the Oracle® Enterprise Session Border Controller (E-SBC).
You can download any of the following file types from your local server or PC to the E-SBC:
- Backup configuration
- Local route table (LRT)
- Fraud protection table
- Log
- Playback media
- Software image
- SPL Plug-in (SPL)
Delete a File
Procedure and conditions for deleting a file from the Oracle® Enterprise Session Border Controller (E-SBC).
You can delete any of the following file types from your local server, PC, and E-SBC:
- Backup configuration Software image
- Log
- Playback media
- Software image
- SPL Plug-in (SPL)
You can select a single or multiple files to delete.
