| Siebel CRM Siebel Mobile Guide: Connected Siebel 2018 E52426-01 |
![]() Previous |
![]() Next |
View PDF |
To set up CardDAV dynamic mapping between Siebel objects and CardDAV properties, do the following:
Make sure that the following CardDAV Workflows are activated:
SiebDAV vCard Sync Decision Sub Process
SiebDAV vCard Sync Process
(Required) Define System Preference to point to the CardDAV main workflow:
Name = "CardDAV Dynamic Mapping WFP" Value = "SiebDAV vCard Sync Process"
(Optional) To enable Google Maps Geocoding API integration to normalize the address, define System Preference for Google Maps Geocoding API integration as follows:
Name = "Google API Key" Value = ""
For more information about Google Maps Geocoding API, see "Google Maps Geocoding API Integration".
