| Siebel CRM Siebel Mobile Guide: Connected Siebel 2018 E52426-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel CardDAV dynamic mapping is supported on:
iOS 9.x mobile devices with vCard 3.0.
Third-party CardDAV clients:
For Android, such as, Kerio Connect Sync Android client or CardDAV-Sync Android CardDAV client.
For Outlook, such as, Outlook CalDavSynchronizer plugin (sync Outlook with Google, SOGo, or any other CalDAV or CardDAV server).
Note: These are examples of CardDAV clients and are not supported by Oracle. |
To override the supported CardDAV clients, add the User Properties to the CalDAV Service business service where for example:
Name = "Supported CardDAV UserAgent Prefix 2" Value = "iOS/10"
For example:
"Supported CardDAV UserAgent Prefix 2": "iOS/10"
The prefix in the Value field must be confirmed when the version information becomes available. You must define all the supported CardDAV UserAgent prefixes here so that you override the default supported prefix.
