Siebel Object Interfaces Reference > Siebel Object Interfaces Reference > Technologies You Can Use to Access Object Interface Methods and Events > Technologies You Can Use to Access Object Interface MethodsThis topic lists the technologies you can use to access object interface methods. It includes the following topics:
The term Yes indicates an object interface that you can use with an application method. Applet MethodsTable 8 lists the technologies you can use to access applet object interface methods. You can use an applet object interface method only with Server Script and Browser Script.
Application MethodsTable 9 lists the technologies you can use to access application methods.
Business Component MethodsTable 10 lists the technologies you can use to access business component methods. You cannot use these method with the Web Client Automation Server.
Business Object MethodsTable 11 lists the technologies you can use to access business object methods. You cannot use these methods with the Web Client Automation Server.
Business Service MethodsTable 12 lists the technologies you can use to access business service methods.
Control MethodsYou can use the following control methods. You can use these methods only with Browser Script:
Property Set MethodsTable 13 lists the technologies you can use to access property set methods.
Miscellaneous MethodsTable 14 lists technologies you can use to access other methods that you can use. You cannot use these methods with the following technologies:
| Siebel Object Interfaces Reference | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
