| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
The following guidelines are recommended for improving Siebel EIM performance:
Verify that all indexes exist for the tables involved. Keep in mind, however, that for large loads you must drop most of the indexes from the target tables to increase the speed of the process, rebuilding those indexes afterward when the process is finished.
In some cases, custom indexes might be necessary on EIM tables or base tables, to expedite processing and reduce elapsed time.
Limit tables and columns to be processed using ONLY BASE TABLES/COLUMNS configuration parameters to minimize Siebel EIM processing.
Set the system preference that enables transaction logging during the initial database load. This setting (in the Administration - Siebel Remote screen, and Remote System Preferences view) is a check box labeled Enable Transaction Logging. This setting reduces transaction activity to the Siebel docking tables, which are used for synchronizing mobile clients
Consider disabling transaction logging during the Siebel EIM run. Turning off transaction logging improves performance; however, this benefit must be balanced with the need for mobile users to reextract afterward.
Altering batch sizes to find the optimal batch size for a given business component typically helps resolve performance issues. The batch size is dependent upon the quantity of data and which type of Siebel EIM process that you are running.
Note: Although the limit of rows that you can process is directly related to the capabilities of your database server, executing batches greater than 100,000 rows is strongly discouraged. |
For Siebel EIM delete processes that use the DELETE EXACT parameter, use a batch size of 20,000 rows or less.
Try using batch ranges (BATCH = X-Y). This allows you to run with smaller batch sizes and avoid the startup overhead on each batch. The maximum number of batches that you can run in a Siebel EIM process is 1,000.
Perform regular table maintenance on EIM tables. Frequent insert or delete operations on EIM tables can cause fragmentation. Consult your database administrator to detect and correct fragmentation in the EIM tables.
Delete batches from EIM tables on completion. Leaving old batches in the EIM table wastes space and could adversely affect performance.
Run independent Siebel EIM jobs in parallel.
Set the USING SYNONYMS parameter to FALSE in the IFB file to indicate that account synonyms do not need to be checked.
If no other strategy appears to be successful, then use the SQLPROFILE parameter to identify slow-running steps and queries. For more information, see "Using the SQLPROFILE Parameter".
