| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
This topic provides instructions for configuring and tuning operating system settings and Siebel Enterprise Server components so that you can run Siebel applications on AIX. It contains the following information:
This topic is part of "Tuning Siebel Business Applications for AIX".
AIX provides several environment variables that can be tuned to optimize Siebel Server performance. These environment variables and their values are used as start parameters when the Siebel Server is started. Table 13-1 and Table 13-2 describe each of these environment variables and their recommended settings.
Note: For more information about tuning the Siebel Server, see "Tuning the Siebel Server for All UNIX and Linux Operating Systems". |
Table 13-1 Environment Variables Used for Optimization in $SIEBEL_ROOT/siebenv
| Environment Variable | Value | Description |
AIXTHREAD_SCOPE |
S |
Controls contention scope. S signifies system-based contention scope (1:1). |
AIXTHREAD_MNRATIO |
1:1 |
Controls the M:N ratio of number of kernel threads that must be employed to handle runnable pthreads. |
AIXTHREAD_MUTEX_DEBUG |
OFF |
Maintains a list of active mutexes for use by the debugger. |
AIXTHREAD_RWLOCK_DEBUG |
OFF |
Maintains a list of read-write locks for use by the debugger. |
AIXTHREAD_COND_DEBUG |
OFF |
Maintains a list of condition variables for use by the debugger. |
Table 13-2 Environment Variables Used for Optimization in $SIEBEL_ROOT/bin/siebmtshw
SPINLOOPTIME |
1000 |
Controls the number of times to retry a busy lock before yielding to another processor. |
YIELDLOOPTIME |
>=n
A number greater than or equal to the number of processors. |
Controls the number of times to yield the processor before blocking on a busy lock (only for libpthreads). Set this variable, at the minimum, equal to the number of processors on the computer. |
MALLOCOPTIONS |
buckets,considersize,multiheap:4 |
Include in the value an integer representing the number of processors on this computer. In this case, the value 4 would be used for a four-processor computer. |
LDR_CNTRL |
Example values:
The |
There are several AIX kernel settings that you can tune for optimal Siebel Server or Siebel Application Interface performance under AIX. These include the Virtual Memory Management and TCP settings. You must have root privileges to modify these settings. Use the vmo, ioo, and no commands to tune the AIX kernel. For more information about AIX kernel settings, including several that are not mentioned in this guide, see 1097858.1 (Article ID) on My Oracle Support. See also your operating system vendor's documentation.
To change the kernel settings
Using a text editor such as vi, open the /etc/rc.net file for editing.
Modify settings using ioo and no, following the guidance of 1097858.1 (Article ID) on My Oracle Support.
Note: Use default values for settings forvmo. |
Check the settings for all User Limits (ulimit) and make sure that they are set to -1 (unlimited), as follows:
ulimit if -a
Note: To change the set limits, update the/etc/security/limits file by changing all ulimit parameter values to -1 (unlimited). |
Save your changes and exit the editor.
Make sure that the rpc.statd and rpc.lockd daemons run on the Siebel Server computer and on the server computer where the Siebel File System is located. Then set the number of threads for the rpc.lockd daemon on each applicable server computer.
It is recommended to increase the number of rpc.lockd daemon threads from the default. If possible, use the maximum number of threads, which is 511. System degradation can occur and logins might be blocked if the rpc.lockd daemon is not configured to handle a large number of lock requests. For example, you might execute commands like this:
chssys -s rpc.lockd -a 511stopsrc -s rpc.lockd; startsrc -s rpc.lockd
Restart the server computer to have the new settings take effect.
