| Siebel CRM Performance Tuning Guide Siebel 2018 E24801-01 |
![]() Previous |
![]() Next |
View PDF |
This topic provides instructions for configuring and tuning operating system settings and Siebel Enterprise Server components so that you can run Siebel applications on HP-UX. It contains the following information:
For information about tuning the Siebel Application Interface, see:
This topic is part of "Tuning Siebel Business Applications for HP-UX".
Modify the HP-UX kernel parameters to values like those shown below (suggested guidelines). Use the HP-UX System Administration Manager (SAM) tool to make these changes.
nproc 4096 - 4096 ksi_alloc_max 32768 - (NPROC*8) max_thread_proc 4096 – 4096 maxdsiz 0x90000000 - 0X90000000 maxdsiz_64bit 2147483648 - 2147483648 maxfiles 4000 - 4000 maxssiz 401604608 - 401604608 maxssiz_64bit 1073741824 - 1073741824 maxtsiz 0x40000000 - 0X40000000 msgmap 4098 - (NPROC+2) msgmni 4096 - (NPROC) msgtql 4096 - (NPROC) ncsize 35840 - (8*NPROC+2048+VX_NCSIZE) nfile 67584 - (16*NPROC+2048) ninode 34816 - (8*NPROC+2048) nkthread 7184 - (((NPROC*7)/4)+16) nproc 4096 - 4096 nsysmap 8192 - ((NPROC)>800?2*(NPROC):800) nsysmap64 8192 - ((NPROC)>800?2*(NPROC):800) semmni 1024 - 1024 semmns 16384 - ((NPROC*2)*2) semmnu 2048 - 2048 semume 256 - 256 shmmax 0x40000000 Y 0X40000000 shmmni 1024 - 1024 shmseg 1024 Y 1024 vps_ceiling 64 - 64
Siebel Business Applications will have better performance on HP-UX if you make the following changes, which allow the Siebel Server to execute the HP-UX scheduler upon startup. You must have root privileges to make these changes.
To set permissions for the HP-UX scheduler
Add the following line to the /etc/privgroup file, creating it if necessary:
-g RTSCHED
Save the file and exit.
Execute the following command:
setprivgrp -f /etc/privgroup
Verify that global RTSCHED permissions are set by executing the following command:
getprivgrp
If the command is successful, then the system will respond:
global privileges: RTSCHED
