Siebel Product Administration Guide > Siebel Configurator Technical Reference > Displaying RAL in the Constraints ViewYou can revise the Constraints list to add a field that displays the Rule Assembly Language (RAL) translation of your template rules. This is a useful way to learn how to use RAL to write configuration rules. You must use Oracle's Web Tools to add the field to the Constraints record, and then recompile the siebel.srf file. You must be familiar with creating and modifying applets in Oracle's Web Tools before performing this procedure. To revise the Constraints view, perform the following tasks: Locate the Constraints View AppletThis task selects a target browser and queries for the Cfg SWE Rule Manager Applet. To locate the Constraints View applet
Modify the Constraints View AppletThis task adds the Rule Spec field to the Cfg SWE Rule Manager Applet. To modify the Constraints View applet
| Siebel Product Administration Guide | Copyright © 2018, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
