| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
Table B-1 lists several configuration files and their associated Siebel CRM applications. Your installation might contain additional configuration files besides those listed.
The configuration files are located in the SIEBEL_CLIENT_ROOT\bin\LANGUAGE directory on the Siebel Mobile Web Client. The name of the configuration file varies, depending on the application that you are using. Separate configuration files are provided for each supported language.
Table B-1 Some Siebel Applications and Associated Configuration Files
| Siebel Application | Configuration File |
The initial values for the parameters in the configuration files are either predefined by Siebel CRM or defined using the values that you specify during the initial configuration or at other times.
Some parameter values might include the notation $(param_name). These parameter values are substituted automatically, for example, during a client installation or local database initialization. For example, the value of the ConnectString parameter for a data source that has not yet been configured appears as follows:
ConnectString = $(ConnectString)
This parameter value is updated when you initialize the local database for a Siebel Mobile Web Client. For more information about initializing the local database, see Siebel Remote and Replication Manager Administration Guide. See also the Siebel Installation Guide for the operating system you are using.
