| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
Environment variables are variables configured for a particular computer hosting an aspect of a Siebel CRM deployment. These Siebel-specific environment variables configure interactions with the computer's operating system and various functions of Siebel CRM applications. Configure environment variables through the operating system of the individual computer. For information about configuring these variables, see "Configuring System Environment Variables".
Environment variables configure a wide range of functionality and are covered in context-specific areas of the Siebel Bookshelf. The Siebel Bookshelf is available on Oracle Technology Network (OTN) and Oracle Software Delivery Cloud. It might also be installed locally on your intranet or on a network location.
Table 3-1 provides a partial listing of environment variables for Siebel CRM or that affect the Siebel CRM applications, and it indicates one or more locations where each variable is documented. This list is not comprehensive. Some environment variables are set automatically. In general, you set environment variables explicitly only as you are instructed by documentation for Siebel CRM.
Table 3-1 Partial Listing of Siebel Environment Variables
| Environment Variable | Where Documented |
NLS_LANG |
Siebel Installation Guide for the operating system you are using |
NLS_SORT |
ORACLE_HOME |
PATH |
SIEBEL_CODEPAGE |
TEMP |
TMP |
LD_LIBRARY_PATH (Linux and Oracle Solaris) |
Siebel Installation Guide for UNIX |
JAVA_HOME |
LANG |
LC_ALL |
LIBPATH (AIX) |
NLS_DATE_FORMAT |
ODBCINI |
SHLIB_PATH (HP-UX) |
SIEBEL_HOME |
SIEBEL_GATEWAY_ROOT |
SIEBEL_SERVER_ROOT |
SIEBEL_ROOT |
SIEBEL_ENTERPRISE |
SIEBEL_UNIXUNICODE_DB |
TNS_ADMIN |
SIEBEL_ASSERT_MODE |
Siebel Performance Tuning Guide Siebel System Monitoring and Diagnostics Guide |
SIEBEL_OSD_LATCH |
Siebel Performance Tuning Guide |
SIEBEL_OSD_MAXLIMITS |
SIEBEL_OSD_NLATCH |
SIEBEL_OSD_PTHREAD_STACK_SIZE |
Siebel Performance Tuning Guide 2007183.1 (Article ID) on My Oracle Support Note: This environment variable applies only to supported versions of UNIX or Linux operating systems. |
SIEBEL_SARMBufferSize |
SIEBEL_SARMFileSize |
SIEBEL_SARMLevel |
SIEBEL_SARMMaxFiles |
SIEBEL_SARMPeriod |
SIEBEL_CRASH_HANDLER |
SIEBEL_DIAG_STORE |
SIEBEL_LOG_ARCHIVES |
SIEBEL_LOG_DIR |
SIEBEL_LOG_EVENTS |
SIEBEL_SESSMGR_TRACE |
SIEBEL_SISNAPI_TRACE |
SIEBEL_STDERROUT |
SIEBEL_DATA_SOURCE |
Using Siebel Tools |
SIEBEL_TABLE_OWNER |
SIEBEL_FILE_ENCODING |
Siebel Marketing User Guide |
SPELLCHECKLEVEL1 |
Set to True when using the spell check feature with outbound email messages. For more information about this feature, see Siebel Email Administration Guide. |
RESOLV_MULTI |
1435205.1 (Article ID) on My Oracle Support Note: This environment variable applies only to supported versions of Oracle Enterprise Linux. |
