| Siebel CRM System Administration Guide Siebel 2018 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes how to configure system environment variables on Windows and on UNIX. For more information about Siebel-specific environment variables, see "About System Environment Variables". For a list of some of the Siebel environment variables, see Table 3-1.
This procedure describes how to configure an environment variable on Windows.
To configure an environment variable on Windows
Choose Start, Settings, Control Panel, and then double-click System.
Click the Advanced tab, then click Environment Variables.
In the System Variables section, click New to create a new environment variable.
For a partial list of Siebel environment variables, see Table 3-1.
Set the Variable Name field to the name of a Siebel environment variable.
Set the Variable Value field to the value for the Siebel environment variable.
Restart the computer for the environment variables to take effect.
This procedure describes how to configure an environment variable on UNIX.
To configure an environment variable on UNIX
Log in as the Siebel Service owner user.
Run the siebenv.sh or siebenv.csh script to set Siebel environment variables. For more information about these scripts, see Siebel Installation Guide for UNIX.
Depending on the type of UNIX operating system that you use, enter a command like the following to set the environment variable.
For Korn shell:
exportSiebel_Environment_Variable=Variable_Value
For C shell:
setenvSiebel_Environment_VariableVariable_Value
where:
Siebel_Environment_Variable is a Siebel-specific environment variable.
Variable_Value is the setting for the environment variable.
For example, enter the following command for C shell:
setenv SIEBEL_SARMLevel 1
