PreviousNextJavaScript must be enabled to correctly display this content
Hardware Installation Summary
Installing your
Oracle Enterprise Communications
Broker in your rack requires the steps summarized here. This checklist is only an overview. It is not designed to substitute for following the detailed procedures in the hardware installation guides.
Unpacking the
Broker
Installing the
Broker into your rack
Installing power supplies
Installing fan modules
Installing physical interface cards
Cabling the
Broker
Make sure you complete installation procedures fully and note the safety warnings to prevent physical harm to yourself and/or damage to your
Broker.
After you have completed the hardware installation procedures, you are ready to establish a connection to your
Broker. Then you can load the
Broker software image you want to use and establish basic operating parameters.
