Connecting to Your Net-Net ECB
By default, Oracle delivers the Oracle Enterprise Communications Broker (OECB) with no management IP address. You must set this address the first time you start the system. See the System Boot section.
You can connect to the OECB through a direct console connection or by creating a remote SSH session. Both methods provide a wide range of configuration, monitoring, and management options. IP-based management access, including SSH and the web GUI, requires an IP address for your management port. This address is specified in the ip address boot parameter.
The system displays the ip address parameter with different names, depending on the context:- The boot parameters wizard field name is also ip address.
- The initial configuration wizard field name is Management interface ip address.
- The ACLI show interfaces command field name is wancom0.
By default, SSH, SFTP, and web GUI connections to the OECB are enabled, but are only accessible by way of the ip address. You cannot use SSH, SFTP, or the web GUI until you set this address.
Depending on the platform, you may need to install the software installation upon first startup. You perform and monitor software installation by way of the console connection. The OECB requires most configuration by way of the web GUI. Procedures requiring the ACLI include:
- Change default management interface IP address
- Format hard drive
- Set and change password
- Set and change SIP Monitor and Trace filters
Local Connections and Time-outs
The ACLI is available through serial and SSH connections. Prior to software installation, you reach the ACLI through a local, serial connection.
When deploying the Oracle Enterprise Communications Broker (OECB) on a virtual machine, the virtual machine manager provides console access through a virtual serial connection. See documentation on your virtual machine to learn how to access the console. Working with the virtual machine console is the same as working on dedicated hardware.
When deploying on dedicated hardware, refer to the hardware documentation "Applicable Platforms" for instructions on connecting to the OECB console.
Plug one end of the cable into your terminal and the other end into the RJ-45 port, normally located on the back of your server.
To set up a console connection to the OECB:
SSH Connections and Time-outs
You can use SSH to connect to the Oracle Enterprise Communications Broker (OECB) and provision the OECB remotely through the management interface over IP. You configure the management interface IP during system setup, or by way of the OECB boot parameters.
The Oracle Enterprise Communications Broker can support up to five concurrent SSH and SFTP sessions. Note that only one user can carry out configuration tasks at a time.
To connect to the OECB, you need to know the IP address of its administrative interface (wancom0). You can find the OECB wancom0 IP address by using the ACLI to display the boot parameter value named IP Address.
You can manage the SSH connections to the OECB by setting certain ACLI parameters and by using certain commands:
- To view the users who are currently logged into the system, use the show users command. You can see the ID, timestamp, connection source, and privilege level for active connections.
- From Superuser mode in the ACLI, you can terminate the connections of other users to free up connections. Use the kill user command, with the corresponding connection ID.
- When you reboot the OECB from an SSH session, you lose IP access and the connection.
Initiate SSH without Username and Password
Many SSH clients allow you to initiate an SSH connection without specifying a username. To initiate an SSH connection to the Oracle Enterprise Communications Broker (OECB) without specifying usernames and SSH user passwords:
SSH with Username and Password
To initiate an SSH connection to the Oracle Enterprise Communications Broker with an SSH username and password:
GUI Access
To access theOracle Enterprise Communications Broker (OECB) for ongoing configuration and management, you must use the GUI. The system allows only a few user and provisioning procedures by way of the ACLI, such as setting the initial management IP address and changing GUI access passwords. The system does not allow disabling the GUI.
You can configure GUI access by way of HTTP or HTTPS at the configured management address, which you must set prior to attempting to log on.
When a user accesses the GUI, the OECB displays the log on screen. Upon successful log on, the system allows access to the System Administration and Service Provisioning controls.
